ACL Bearings good?
Old May 8, 2003 | 07:07 PM
JMinSi2000's Avatar
Default ACL Bearings good?
Did a search and didn't come up with anything of use. Anybody used them?
Old May 8, 2003 | 07:09 PM
hatchy's Avatar
Default Re: ACL Bearings good? (JMinSi2000)
oem
Old May 8, 2003 | 07:13 PM
BlueSi2k's Avatar
Default Re: ACL Bearings good? (hatchy)
I have seen nothing but great results from ACL bearings. I can't remember ever hearing a bad thing. I personally am using them in my rebuild and they were all well within spec
Old May 8, 2003 | 07:26 PM
Tinker219's Avatar
Default Re: ACL Bearings good? (BlueSi2k)
performance build here, great. all within spec...highly recommend.
Old May 8, 2003 | 08:59 PM
Slick GS-R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchy &raquo;</TD></TR><TR><TD CLASS="quote">oem </TD></TR></TABLE>
Old May 8, 2003 | 11:06 PM
Specs's Avatar
Default Re: ACL Bearings good? (Slick_GS-R)
ACL bearings are used not only by the Top pro racers but alot of H-T members have used them also, and price is very reasonable.They come in STD which in honda color code is Brown.is that correct guys.?? Complete bearing kit which includes
Main Bearings
Rod Bearings
thrust washer
goes for about $99 and includes Assembly lube and Plasticgauge
Camp1320 has them in stock and ready to ship. check out his website at http://www.camp1320.com
Old May 8, 2003 | 11:09 PM
TurboDANDEE's Avatar
stock bearings
Old May 9, 2003 | 08:40 AM
BlueSi2k's Avatar
Default Re: ACL Bearings good? (burp)
yes for camp1320.com...he had my bearings at my door in 2 days
Old May 9, 2003 | 10:39 AM
Muckman's Avatar
Moderator in Chief
Default Re: ACL Bearings good? (specs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by specs &raquo;</TD></TR><TR><TD CLASS="quote">ACL bearings are used not only by the Top pro racers but alot of H-T members have used them also, and price is very reasonable.They come in STD which in honda color code is Brown.is that correct guys.?? </TD></TR></TABLE>
I dont understand if they only come in one size (brown) how can they work? It was my understanding that Honda engines were built to very tight specs from the factory and required each engine to have different size bearings (within the range of course).
Old May 9, 2003 | 10:45 AM
shermanyang's Avatar
Default Re: ACL Bearings good? (Muckman)
I've had my ACL bearings in my built motor for about a year now. no problems and runs great.
Old May 9, 2003 | 11:14 AM
Scott - 93HB Si's Avatar
Default Re: ACL Bearings good? (shermanyang)
I run only OEM bearings in my motors.
I've seen the wear that happens when you run too loose or tight on bearinsg, and IMO it's better to run the right clearences.
Race motors are a different thing. When you run 'slightly' looser you have less friction and can make a little more power.....better to run proper clearence tho in a motor that will see a lot of miles.
Old May 9, 2003 | 11:18 AM
RyanEJ8's Avatar
Default Re: ACL Bearings good? (Scott - 93HB Si)
I thought the ACL's came with stock clearances?
Old May 9, 2003 | 11:22 AM
AVATAR's Avatar
[QUOTE=specs]ACL bearings are used not only by the Top pro racers but alot of H-T members have used them also...
QUOTE]
What "Top pro racers" are running them? Are they all the same clearances like the ones customers get?
Old May 9, 2003 | 11:30 AM
Mr. Softee's Avatar
Default Re: ACL Bearings good? (AVATAR)
I had thought if you were going to use them you had to balance your bottom end to the brown color's specs.
Old May 9, 2003 | 01:43 PM
Flamenco-T's Avatar
Default Re: ACL Bearings good? (94goldjungsr)
ACL are designed for Green and Brown Color. If you're color in between green, yellow and brown, you can use ACl and you'll be within specs.
if your color is black or pink, you may neet to machine the journal to the green spec, but if you have to do this, just get OEM bearings.
I have 4 green and 1 yellow on Main, and 3 green and 1 brown on Rod. I Used ACL and all DEAD within specs.
stan
Old May 9, 2003 | 02:07 PM
RyanEJ8's Avatar
Default Re: ACL Bearings good? (Flamenco-T)
Which color should I be using with Eagle rods in my D16Y8?
Old May 9, 2003 | 04:15 PM
BlueSi2k's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flamenco-T &raquo;</TD></TR><TR><TD CLASS="quote">ACL are designed for Green and Brown Color. If you're color in between green, yellow and brown, you can use ACl and you'll be within specs.
stan
I have pretty much the same color codes as you...plastigaged them last week...perfect
Old May 9, 2003 | 04:32 PM
boostaholic's Avatar
I've been using ACL bearings. They were all within spec so i didn't have any problems sizing them up.
Old May 9, 2003 | 04:47 PM
porsche997dc2's Avatar
Default Re: ACL Bearings good? (boostaholic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostaholic &raquo;</TD></TR><TR><TD CLASS="quote"> They were all within spec so i didn't have any problems sizing them up.</TD></TR></TABLE>
same here
Old May 9, 2003 | 05:18 PM
TREVER's Avatar
Default Re: ACL Bearings good? (porsche997)
I like oem
nothing against acl
Old May 9, 2003 | 06:30 PM
Sonny's Avatar
ACL's will fit most people's engines, they work well, and they aren't on backorder half the time you need them.
I used ACL.
Sonny
Old May 12, 2003 | 06:50 PM
Zeus's Avatar
Default Re: ACL Bearings good? (Sonny)
When I rebuilt the GSR a few months back, they were all with in spec.
Old May 20, 2003 | 07:18 AM
ludesleep's Avatar
Default Re: ACL Bearings good? (Zeus)
well how many people here have "HAD" problems with acl?
Old May 20, 2003 | 11:53 AM
blackANESE's Avatar
Default Re: ACL Bearings good? (ludesleep)
My ACL are just fine
Old May 20, 2003 | 12:47 PM
95TurboLS's Avatar
Default Re: ACL Bearings good? (blackANESE)
Ive had mine for 5000 miles now and they are fine!
