where do you gap your plugs?
Old May 9, 2003 | 04:54 PM
extrmeboost's Avatar
Default where do you gap your plugs?
with my sohc turbo my plugs are gapped at 22, i know this is a really small gap, but where are yours at?
Old May 9, 2003 | 05:17 PM
ladysman's Avatar
Default Re: where do you gap your plugs? (extrmeboost)
.32
RyanAutry's Avatar
.030
Old May 9, 2003 | 05:21 PM
b18cTurbo's Avatar
Old May 9, 2003 | 05:22 PM
boosted hybrid's Avatar
.030 with anything under 15lbs
.024~.026 with anything over 15lbs
This is also with a msd 6a and blaster coil. I also run a heat range 7 for anything under 15psi, and a heat range 8 for anything over 15psi.
Old May 9, 2003 | 05:49 PM
ladysman's Avatar
Default Re: where do you gap your plugs? (boosted hybrid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted hybrid &raquo;</TD></TR><TR><TD CLASS="quote">.030 with anything under 15lbs
This is also with a msd 6a and blaster coil. I also run a heat range 7 for anything under 15psi, and a heat range 8 for anything over 15psi.</TD></TR></TABLE>
What is the part number for the 8 series plugs you use?
Can these be used for D series?
Old May 9, 2003 | 06:00 PM
Default Re: where do you gap your plugs? (ladysman)
Not sure off the top of my head. I know that they are a race plug, and I have to special order them when I get them from a local shop. I usually just bring in the box and have them reorder them when I need them.
Old May 9, 2003 | 06:01 PM
ladysman's Avatar
When you order them again, I could use the part number.
Thanks for your help.
Old May 9, 2003 | 06:28 PM
SOUNDEFFECTS's Avatar
bcpr7es-11 for heat range 7 series plugs-available everywhere! Discount, Napa, Pep boys....Napa by me is always in stock
Old May 9, 2003 | 06:42 PM
ion_four's Avatar
Default Re: where do you gap your plugs? (SOUNDEFFECTS)
I gap my plugs in bed haha, lol...oh, my god....
anyway...I gap them so I can't fit the .035 through them, but I can fit the .032...really accurate, eh?
Old May 9, 2003 | 09:16 PM
EVOLMTR's Avatar
Default Re: where do you gap your plugs? (ion_four)
32
Old May 9, 2003 | 10:48 PM
swrdply400mrelay's Avatar
Default Re: where do you gap your plugs? (EVOLMTR)
0.034"
Old May 9, 2003 | 11:19 PM
tony1's Avatar
R5671A-8 is the part number for the 8's
Old May 10, 2003 | 12:40 AM
eg6turbo's Avatar
Default Re: where do you gap your plugs? (tony1)
ngk 7's at .35 at 8 psi....10 psi at the track i run .30-.31....
og9817
Nov 13, 2003 06:21 AM
Rhetoric
Apr 17, 2003 11:07 AM
Boostless97Lude
Feb 22, 2003 01:35 PM
SIK IN DA HED
Aug 13, 2002 02:43 PM
Duck Sauce
Jan 13, 2002 06:17 PM
