Timing
Old May 9, 2003 | 09:45 PM
99turbosi's Avatar
Default Timing
Does anyone know where the timing should be set at on a 99 civic si with a turbo (t3/t4) @ 9psi? Or maybe a suggestion of where it should be set at to make it run the best?
Old May 9, 2003 | 09:51 PM
EVOLMTR's Avatar
Default Re: Timing (99turbosi)
Each set-up is different.
Most people run 1 degree retard per lb of boost to be safe.
I run 12 degrees retard @ 9psi
This is until I go hondata.
Old May 9, 2003 | 09:55 PM
DIRep972's Avatar
Smarter than you
Default Re: Timing (EVOLMTR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EVOLMTR &raquo;</TD></TR><TR><TD CLASS="quote">Each set-up is different.
no most people run about .5deg retard per psi up until 10lbs, after that the common retard is about .75deg/psi. 1deg/psi is alot.
If ur not running hondata or any type of timing control device it would be a smart idea to set the distributor back to 12-14deg. w/ a timing light for an Si @ 9psi. Low end will suffer but at least u will be safe.
Old May 9, 2003 | 10:27 PM
BoostedSi's Avatar
Default Re: Timing (DIRep)
At 1 deg of retard per pound with my msd it used to drive like ****. I went with .5 per pound with the msd. Then i did .75 deg with my aem.
Old May 9, 2003 | 11:54 PM
turb's Avatar
i'm currently using the vafc hack with my setup. will an apex itc help me control my timing? will an itc be better than a btm?
wfocrx
Apr 12, 2007 01:14 PM
dominate9
Dec 22, 2003 09:14 PM
B_1_8_hatch
Jul 28, 2003 01:33 PM
TurboDC4
Feb 7, 2003 02:29 PM
hybrid901
Sep 11, 2002 05:33 PM
