vafc hack and profec b
Old May 7, 2003 | 03:45 PM
joeski's Avatar
Default vafc hack and profec b
ok heres a big question i did a search but couldnt find any info on this
im goin to install my turbo set up next week and am goin to use the hack but i noticed everyone who uses it keeps there boost at liek 9psi i also have a profec b boost controller and want to be able to adjust the boost for everyday driving to conserve gas and ****, i want to knwo if i could run the hack with the profec or would it mess up the running of the car ex like stubling or runing rich or lean
any info would be a big help thanxk guys
Old May 7, 2003 | 04:35 PM
ELSpool's Avatar
Well if you tune for a certain psi, and then the next day you drop the boost down a few pounds, you going to be runing pig rich and probably use the same amount of gas because you injectors are open for whatever you have the AFC set at. IMO I think theres no point to have the profec but it will help spool time increae abit. YOu need something like hondata where if you drop the boost, the MAP reads it and lowers fuel accordingly.
Old May 7, 2003 | 09:05 PM
joeski's Avatar
Default Re: (HiRolla)
yea im saving for a hondata now and was curious about the settings thanx alot
Old May 7, 2003 | 09:10 PM
deebee-II's Avatar
the diff between afc hack and hondata will be like night and day
Old May 7, 2003 | 10:04 PM
MiraiZ's Avatar
I thought the AFC read MAP pressure....if it does, you shouldn't have problems changing boost pressure
Old May 8, 2003 | 12:09 PM
ntegls's Avatar
Default Re: (MiraiZ)
bump
bOOsT-FeIn
Jul 9, 2007 09:17 AM
civic_66
Feb 14, 2007 07:22 AM
btrim23
Feb 26, 2005 02:32 PM
dirtySOHC's
Jul 16, 2003 06:22 PM
_Endless_
May 19, 2003 08:33 AM
