309 whp stock b18c1 at 8lbs
we just got on the dyno today,two runs only 309whp and 219 lbs of torque,stock b18c1 on 8lbs,timing set at 16,cams set at 0,chipped p72,310 rc injectors,fmu, chart will be up soon
Re: 309 whp stock b18c1 at 8lbs (singleslamrex)
I hope you have an A/F graph to go along with that. My guess is that you are running pretty lean. I got 280whp at 6psi when I was running an FMU and it was mainly due to a 13-13.5 A/F up till 5500rpms in which it started richening up to 12.5 A/F to readline.
Good numbers non the less, but make sure its safe reliable HP.
Re: 309 whp stock b18c1 at 8lbs (arsenaldragster)
yeah it was getting on the lean side,its was going around 13.5,but fixing that tomorrow with new fuel pump
bone stock gsr motor,330 rc injectors,not sure but i think its a kg turbo manifold,t3 t4,spearco intercooler,fmu,delta wastegate,chipped p72,stock cam timing,timing 16,at 45 psi fuel pressure,i made two runs on the dyno,3 inch down pipe and mandral bent piping and an exhaust off a diesel
i can belive it alamo autosports cranked out 450whp on a fulley built b18c1 with 10 psi, i was like i dont belive it then i went up there watch and yeah they were rite low boost high numbers..
Re: 309 whp stock b18c1 at 8lbs (Prelude Vtec 23)
it was dynoed at sleeper motorsports in san bernadino,i pieced the kit together.it would have made more power.
Location: You can be my wingman anytime...., Las Vegas, US
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Prelude Vtec 23 »</TD></TR><TR><TD CLASS="quote">impressive </TD></TR></TABLE>
very
very
1 Post
Re: 309 whp stock b18c1 at 8lbs (sweet)
High compression, low boost is where its at. Just wait, in a year, people will be boosting 12:1 compresion motors, and making 600whp on 10psi...no joke
Re: 309 whp stock b18c1 at 8lbs (Tinker219)
you said 310cc injectors in your first post and 330cc in another which is it? Doesnt' seem like you know alot about your set up, but great numbers anyways. It must be that chipped ecu. B16ahybrid made only 227 on 9psi with a perfect a/f. I just wonder how some motors make more if every thing is the same?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by singleslamrex »</TD></TR><TR><TD CLASS="quote">we just got on the dyno today,two runs only 309whp and 219 lbs of torque,stock b18c1 on 8lbs,timing set at 16,cams set at 0,chipped p72,310 rc injectors,fmu, chart will be up soon</TD></TR></TABLE>]
sounds like a scary combination
