Is this a good deal?
Old May 8, 2003 | 12:14 AM
TypeDC4's Avatar
Default Is this a good deal?
Well guys I finally saved enough money for my turbo kit. I'm getting a used Drag III kit installed for $2200 this weekend.You guys think this is a good deal or what?It was used for less then 8 months and he's throwing in a turbo timer, boost gauge, and egt gauge with pod. Is there anything I should buy for the turbo installation like spark plugs, gaskets etc...Thanks you guys
Old May 8, 2003 | 12:17 AM
ninesecrx's Avatar
Default Re: Is this a good deal? (TypeDC4)
run a step colder spark plug and the highest octane pump gas u can. Its probably a good deal if the kits ok and if you cant do the work your self, thats good cause a shop charges around 500-800 bucks to install anyways.
Old May 8, 2003 | 12:31 AM
TypeDC4's Avatar
Default Re: Is this a good deal? (ninesecrx)
Well I just replaced my spark plugs with NGK V power is that coo? Its actually a guy installing it in his garage for $300...anything else like gaskets or anything, anything i should do when starting it up for the first time? thanx for the reply ninesecrx, anymore?
InTeGrA_bLazEd
Jun 27, 2007 11:02 PM
Brycen
Aug 21, 2005 08:58 PM
HYREV2NR
Nov 16, 2003 09:13 PM
