UberChip Dyno Results Inside!
Old May 6, 2003 | 10:22 PM
94TealGSR's Avatar
Default UberChip Dyno Results Inside!
Ok, here it is. Stock LS @8psi, with UberChip. EDIT: It's untuned.
Old May 6, 2003 | 10:25 PM
95TurboLS's Avatar
Default Re: UberChip Dyno Results Inside! (94TealGSR)
Nice. Looks Way rich.
Old May 6, 2003 | 10:28 PM
turbospool's Avatar
Default Re: UberChip Dyno Results Inside! (95TurboLS)
whats your set up, kit etc.
Old May 6, 2003 | 10:29 PM
Daniel's Avatar
yeah, looks very rich. Better to play safe than blow up, though, eh?
Old May 6, 2003 | 10:31 PM
Mase's Avatar
Default Re: UberChip Dyno Results Inside! (Daniel)
would have probably made more power w/ a damn fmu and inline pump
Old May 6, 2003 | 10:32 PM
tegasaurus's Avatar
Default Re: UberChip Dyno Results Inside! (Mase)
its a t3/t4B... not an e guys
some tuning of the a/f and ignition curve could extract a good bit more amount of hp.
95TurboLS's Avatar
It will be fine when its tuned
Old May 6, 2003 | 10:34 PM
Mase's Avatar
Default Re: UberChip Dyno Results Inside! (tegasaurus)
i put out 270 on a t04b at 10.5 psi.
Its not the turbo.
turbospool's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mase &raquo;</TD></TR><TR><TD CLASS="quote">would have probably made more power w/ a damn fmu and inline pump </TD></TR></TABLE>
word
Old May 6, 2003 | 10:35 PM
95TurboLS's Avatar
Yours was prob tuned though?
Old May 6, 2003 | 10:36 PM
94TealGSR's Avatar
Not my setup, but...
Drag manifold
T3/T04B
TiAL WG
TurboXS RFL BOV
Sonny's Avatar
I'd say that's a pretty damn good base map given that he just guessed conservatively on the fuel and ignition values. Definitely better to be safe than sorry if you're selling to the masses.
Sonny
Old May 6, 2003 | 10:37 PM
Mase's Avatar
yep, it was. but still. those chips are worthless if you dont tune them, i seriously know a fmu and inline will put down more power than that.
Old May 6, 2003 | 10:40 PM
94TealGSR's Avatar
Hey, as I said, this is untuned. This was a baseline, no tuning involved. Check back in a few weeks for the tuned edition of this dyno plot.
Old May 6, 2003 | 10:42 PM
Joseph Davis's Avatar
You can bash Blake as a person, and everybody laughs and agrees. Bashing a real world accomplishment because you dislike someone is ******* immature.
It's a cheap, UNtuned chip sent out the door pig rich so a "tard," as Blake would say, won't blow something up. It makes sucessful power without risking your engine like the inline + FMU would. If the person getting dyno'd had the actual dirt ******* cheap tuner app, and their head out of their ***, they would have had the "usual" numbers for their setup. Can you disagree with any of this?
Old May 6, 2003 | 10:43 PM
Sonny's Avatar
Yes, but what can you do to tune the FMU an inline pump?
Nothing.
Raise/lower fuel pressure, but that's it. That ain't gonna do jack. I did the FMU route initially and it was piece of **** and a total waste of time and money.
The base map may not make a lot of power, but the fact that you can tune the chip for another $100 is a helluva deal. I'm happy with my Hondata and it's additional features, but for the price, the Uberchip is a bargain...even if the developer's social skills leave a little to be desired.
Sonny
Old May 6, 2003 | 10:44 PM
94TealGSR's Avatar
Default Re: UberChip Dyno Results Inside! (J. Davis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J. Davis &raquo;</TD></TR><TR><TD CLASS="quote">
If the person getting dyno'd had the actual dirt ******* cheap tuner app, and their head out of their ***, they would have had the "usual" numbers for their setup.</TD></TR></TABLE>
Hey now, be nice. He has the software. Tuning is way more $ than a basemap. Like I said, stay tuned for a tuned version. No heads in asses here.
Old May 6, 2003 | 10:48 PM
Sorry ;p
Old May 6, 2003 | 10:53 PM
DIRep972's Avatar
Smarter than you
mase is right about the inline/fmu. but its not really the fuel, its the timing.
I made 230/198 on my set up @ 8lbs w/ stock timing and 11:1 a/f just like on that dyno graph. w/ the hondata @ .7deg retard per psi and 12:1 a/f I made 225/195
You are loosing alot of power from timing. Ive read that ubers chip has 1deg retard per psi. you could probably make about 15 more whp w/ some safe advance and cleaner a/f.
Personally I would never run a chip made by someone I don't trust. His personal turbo set up and his attitude are what made me think twice about running the chip. and eventually turning his offer down. Hopefully it works out for u guys.
Old May 6, 2003 | 10:54 PM
95TurboLS's Avatar
Default Re: UberChip Dyno Results Inside! (DIRep)
What about if he just changed the ign timing to .7 and kept the rest the same?
Old May 6, 2003 | 10:59 PM
DIRep972's Avatar
Smarter than you
actually my bad. when I made 225whp @ 8lbs that was w/ .7deg retard/psi in boost but 2deg total advance all the way accross the map. The Actual value was about 27deg @ 8lbs 5k-7k rpms, for anyone wondering. w/ ubers chip I think it is more like 22-23.
Mase's Avatar
You can bash Blake as a person, and everybody laughs and agrees. Bashing a real world accomplishment because you dislike someone is ******* immature. </TD></TR></TABLE>
Thats funny, i dont remember saying anything about "blake" I was talking about the chip. I honestly think its very cool that someone came up w/ this, but i dont think its a good idea to just throw out a bunch of chips. however i do like the fact they are tune-able.
It's a cheap, UNtuned chip sent out the door pig rich so a "tard," as Blake would say, won't blow something up. It makes sucessful power without risking your engine like the inline + FMU would. If the person getting dyno'd had the actual dirt ******* cheap tuner app, and their head out of their ***, they would have had the "usual" numbers for their setup. Can you disagree with any of this?</TD></TR></TABLE>
hrmm, so you're saying there is no risk w/ this chip? i know you know too little timing can destroy a motor too, and running awful rich isnt the best idea in the world either.
regardless, i think it will be just fine w/ tuning.
Old May 6, 2003 | 11:02 PM
Sonny's Avatar
LOL...you changed your nick again??
1 deg/psi is definitely reeallly conservative on the ignition advance. However, that's something I'd feel comfortable in giving people and telling them it's safe to boost on.
I gave my highly tuned Hondata JRSC map to a lot of people, but I always pulled a lot of timing out of the map before giving it to them. I didn't want the liability of a blown motor because my settings were too aggressive for someone else's setup.
Sonny
Old May 6, 2003 | 11:05 PM
Default Re: UberChip Dyno Results Inside! (Sonny)
Mase, you're in another Uber-thread, your dislike is obvious and has been for a long time. I like you inasmuch as I know you, and this doesn't suit you.
Old May 6, 2003 | 11:12 PM
Mase's Avatar
obviously you've read it all wrong there cool guy. I like the uberchip w/ the tune-able feature, I dislike uberteg sure. This thread has nothing to do w/ uberteg personally, so ******* leave him out of it..
But just because i dont like someone doesnt mean that their product couldnt work. I'd still recommend the chip to someone who cant afford a higher end standalone....just not the untuned blowing black smoke, misfiring chip.
