Roller Rockers & Roller Cams question?
Old Apr 13, 2012 | 02:43 PM
Ex MR2 Owner's Avatar
Default Roller Rockers & Roller Cams question?
A quick question... Is there a company or web site that sells non V-TEC Roller Rockers or Roller Cams? I know Ferrea sells them for the V-TEC 1.6 & 1.8 motors, but I would like that type of set up for the non V-TEC 1.8 DOHC.
Any type of information would be great.
Old Apr 13, 2012 | 03:26 PM
Turbo-LS's Avatar
Default Re: Roller Rockers & Roller Cams question?
No one has ever or probably will ever make a rocker upgrade for the non vtec head although it would be very beneficial IMO
Old Apr 13, 2012 | 04:26 PM
Awesome thanks for the reply. I guess I'll be buying a V-Tec head... would of liked to work with what I had, but no big issue though. Thanks again.
Old Apr 13, 2012 | 04:30 PM
Turbo-LS's Avatar
What are you trying to do? Just be ause you can't get roller rockers doesn't mean you can't use the head. Just valve springs and retainers and the right cams will make power and give you ability to rev to T least 8k.
Old Apr 13, 2012 | 04:31 PM
dcmatt's Avatar
The ls heads flow is horrible. Your much better off getting a vtec head. It would take some expensive port work to get a ls head to flow like a stock port vtec head.
Old Apr 13, 2012 | 04:33 PM
Turbo-LS's Avatar
Here come the one sided vtec is the owner of all. Lol
Yes vtec will make more power but isn't the end all be all cylinder head and depending what the op is trying to do with the car is the route he/she should do. I'm giving and unbiased opinion as I've been down both roads
Old Apr 13, 2012 | 04:38 PM
I just wanted less drag on the internals and less adjusting of them since it was going to be street driven. I'm not trying to have a complete beast on the road either just something nice.
Old Apr 13, 2012 | 04:46 PM
dcmatt's Avatar
I didn't say it was end all be all but ls head sucks. Sure you can use it. I just think its a waste to build one. Just my opinion.
Old Apr 13, 2012 | 04:57 PM
I wanted to make sure I don't float a valve if I did build for high rpm. Plus I am not sure what type of spring to use? the titanium springs eventually wear themselves pretty quick if driven on a basis as a daily car. I'm looking for a 50/50 car reliable and fun around 350- 500 hp.
Old Apr 13, 2012 | 05:07 PM
Turbo-LS's Avatar
Well for that power level go stock vtec head gsr or tyPe r cams will give you 8200rpm
Old Apr 13, 2012 | 05:10 PM
EsotericImage's Avatar
Retired Moderator
Well, the P75 LS head is horrible, the P8R on the other hand flows close to a B16 head..
Old Apr 13, 2012 | 05:21 PM
Sounds good I've heard nothing, but good from the Type R cams. Is there a place you would recommend buying the Type R head from?
Old Apr 13, 2012 | 06:59 PM
Retired Moderator
No place just sells the head.. places sell the whole engine. u can use any vtec head and then use the TR cams (If you can find either)
If your looking for 300-500hp, then you should be looking for a turbo set up. The LS-Vtec can be done to this level, but it will have to go under the knife.
Old Apr 13, 2012 | 09:08 PM
Good stuff. yeah I have the small block set up for a turbo build already should take a decent beating I'm just working on the head right now. I also kind of figured no one would tear open a Type R engine to sell as parts. At least I gave it a try.
Old Apr 14, 2012 | 05:43 AM
nealnanoHX's Avatar
Its not that hard to find Type R parts, cams are the easiest to find the heads are a bit harder and people ask stupid money for them.
Old Apr 14, 2012 | 06:23 AM
Turbo-LS's Avatar
Just be careful when buying used itr ctr cams. there are more and more fakes out there
Old Apr 14, 2012 | 07:41 AM
NA James's Avatar
Our ls head flows damn good. We made 560/321 @ 21psi on pumpgas and it revs to and past 9500rpm with no problems at all.
Old Apr 14, 2012 | 08:06 AM
TheShodan's Avatar
Moderator
not necessarily "fakes", just the incorrect years for what is claimed. Some will sell an ITR only to come find its a GS-R, or even a B16. Sometimes even the sellers don't realize they bought the wrong ones
Old Apr 14, 2012 | 09:26 AM
Turbo-LS's Avatar
Thank you for the correction Mac.
Old Apr 14, 2012 | 09:53 AM
vwbased's Avatar
have a nice day
Retired Moderator
Old Apr 14, 2012 | 04:04 PM
I think I will go the safe route and purchase from the dealer. It may cost more but at least I will know for sure what I am getting.
pleej
Mar 18, 2015 08:56 PM
93' smurf integra
Aug 20, 2007 06:26 PM
BIG T
Jul 21, 2007 08:28 PM
jdmsijdm
Jul 12, 2004 11:51 AM
cloproductions
Dec 29, 2002 01:57 AM
