b20b block with b18 head
Old Apr 14, 2012 | 11:34 AM
540dude's Avatar
Default b20b block with b18 head
I'm currently boosted @ 5psi with a t4 turbo and stock internals.
I want to be able to boost @ 10-12psi safely.
Would I absolutely have to get a full set of forged internals to be able to run 10-12 pounds with a stock b20b block?
Old Apr 14, 2012 | 11:45 AM
SpeedFactoryRacing's Avatar
Default Re: b20b block with b18 head
What size turbo do you have? T4 is a pretty big flange but doesn't specify size. Also how much power do you plan on making?
Old Apr 14, 2012 | 12:41 PM
EsotericImage's Avatar
Retired Moderator
this
we need more info
Old Apr 14, 2012 | 02:49 PM
540dude's Avatar
Sorry, .63
Planning on around 300whp.
Old Apr 14, 2012 | 03:58 PM
yungkhmer's Avatar
i was stock b20z block, built b1 head on 10lbs no problem. Should look into getting arp rod bolts though. Im throwing on a vtec head now and looking for a machine shop in my area to put in arp rod bolts for a sense of security for the bottom end.
Old Apr 14, 2012 | 04:01 PM
damnilovepuzz3d's Avatar
Originally Posted by 540dude
Sorry, .63
No T4 housing has a .63 A/R, that's a T3 housing. Furthermore, still not enough info.
Old Apr 14, 2012 | 04:46 PM
Retired Moderator
well, the ARP's need the rods taken out to be re-sized. if your going thru all that, might as well change up the pistons and rods with a fresh hone and rings. Its alot more work, but will be worth it in the end..
even if you had to stay NA for a while, you can get some ITR replica pistons and bring your CR to 10.X and then use low boost when u decide to boost later on.
Youll have a tune already, some decent #'s till you boost. Rods are cheap, Found a great deal on some rods PM me if interested.
But heres the pistons
http://www.lightningmotorsports.com/.../i-402373.aspx
Just an option.. I mean, your going to have everything out of the block already..
After my build, i wish i wouldve done this option.
Billy ramirez
Sep 15, 2017 09:06 AM
slammedNslowLS
Jul 30, 2009 09:04 PM
b20vtech
Northern California (Sales)
34
Feb 13, 2008 09:03 PM
HUYNH
Dec 13, 2006 05:21 PM
V8 BAIT
Jul 1, 2004 01:18 PM
