Help on Turbo Build
Old Apr 17, 2012 | 09:40 PM
greyEG's Avatar
Default Help on Turbo Build
Hey guys im going to start a turbo build very soon. I am going to use it as a daily driver. I am looking for about 300whp maybe a little less.
My question is what do i have to do to the block to make it the strongest, just to be on the safe side. I have a JDM B18c ( GSR-R). But as of now i am going to be driving a Single Cam. I was gona redo the whole block. The head already has springs and retainers and Skunk2 Tuner 2 Cams.
I was going to put in:
Aftermarket Pistons IDK whick brand (10:1 COMP)
Eagle Rods
Bearings
Piston Rings
.50 or .60 Trim turbo? someone shed some light on this
AND.....
What else for the block so i dont blow anything up.
Old Apr 17, 2012 | 09:47 PM
damnilovepuzz3d's Avatar
Default Re: Help on Turbo Build
There are literally thousands of posts on this forum with the exact info you need
Old Apr 17, 2012 | 09:48 PM
Bix VT's Avatar
300 whp is completely possible on a stock B series block. With new internals you should be more than safe at that range assuming a good tune.
The size of the turbo will depend on where you want spool and what your maximum power goals are. CFM are more important than trim.
Old Apr 18, 2012 | 04:18 PM
greyEG's Avatar
damilove i try looking but i suck at these forum things.
and
Bix VT what is CFM?
Old Apr 18, 2012 | 05:08 PM
EsotericImage's Avatar
Retired Moderator
Start at the top of this page https://honda-tech.com/forums/forumdisplay.php?f=16 << it should look very familiar to you
Edit.. this read is a little outdated, but explains alot. FMU's and other little things arent used anymore.. just read it http://www.beesandgoats.com/boostfaq/g2icturbo.html
Old Apr 18, 2012 | 09:54 PM
Bix VT's Avatar
and
Bix VT what is CFM?
Cubic Feet per Minute. It's a measure of air volume, which is more important than what pressure the air is at.
bigodub93
Mar 3, 2015 02:54 PM
Ghunt521
Sep 10, 2012 11:59 AM
Godspeed07
May 27, 2007 06:02 PM
b16ahybrid
May 8, 2005 01:31 PM
Bulldogg83
Oct 15, 2003 11:06 PM
