b18c or b18b
Old Apr 18, 2012 | 06:09 PM
spades614's Avatar
Default b18c or b18b
Ok i know theres a bunch of on This but i want to know the answer to my particular setup..... ok well I want to sleeve my b18b block and do an all out build my goal is 500whp dd and track ...... going to be using a gt3076r. Gsr head with supertech valves springs stock cams to but i could get a nice gsr block for 350 i thought it would be better becuse or no vtec conversion ,girdle , ... also going to bore to 84mm any insight
Old Apr 18, 2012 | 07:16 PM
4genaccordfreak's Avatar
Default Re: b18c or b18b
The B18c block is a better platform for a basic setup. The B18b block CAN be built just as strong, ie: sleeves, aftermarket crank girdle, full balancing... etc.
I'm sure some others may chime in that 500whp is near MAX output for the GT3076R depending on setup.
If 500whp consistant daily driven is your goal, I would call that unrealistic and unreliable at this point.
Aside from your few sentences. All I see is.. I want this, I want that. I want 500whp with this turbo and these couple mods I listed. What do I do?............
You need to do alot more research and have a solid PLAN in place for an engine and turbo setup, then make a post if you have specific questions. Atleast then other members or I can actually make an informative post.
Old Apr 19, 2012 | 05:42 AM
nealnanoHX's Avatar
If you are going to build the block and sleeve it anyways then just get a B18B block since they are cheaper than a B18C.
Oh yeah and have a longer stroke duu this why I went LS Vtec instead of GSR.
Old Apr 19, 2012 | 01:54 PM
MugenSpeclNY's Avatar
from insight that ive gotten, i would say b18b for the added torque. Dont quote me but ive been told 84mm verse 81mm GSR = est +20 ft/lbs.....84mm with LS crank you could be looking at est +60 ft/lbs vs a 81mm GSR.
Old Apr 19, 2012 | 02:31 PM
speedjunkie_g35's Avatar
From: Pensacola, FL and every Court House in Louisiana
I went with a gsr block because my step brother did a B16 head on a b20 block and couldn't ever get it to stop leaking oil and always had little issues. Less hassle because the block is meant for the head. I am sleeving the block to 84mm and using a LS crank for added torque. I plan on shooting for 500+ by the end of the year.
Old Apr 19, 2012 | 03:05 PM
TheShodan's Avatar
Moderator
Take a LS crank and put it into a sleeved GS-R block.. problem solved in both worlds.
Old Apr 19, 2012 | 03:15 PM
spades614's Avatar
But will the ls crank be able to handle higher revs like 8500
Old Apr 19, 2012 | 03:36 PM
TheShodan's Avatar
Moderator
Absolutely. I do that NOW on my other LS Crank/GS-R Block at 9000... Why wouldn't it? It'd be like any other well-balanced motor. Oh I get it, you heard about that "rod/stroke ratio" jazz. Ignore it. Plan it right, build it right, it'll be fine.
Old Apr 19, 2012 | 06:02 PM
nealnanoHX's Avatar
Probably leaked oil because the wrong head gasket was used. A B20 Vtec is a great setup for all motor and can put out some nice numbers and great tq. If done right that is and it is the same as any LS Vtec. You need to use the head gasket for the bloc you are running amny will use the head gasket for the head they are using and this is known to cause oil leaks from the head. I have a B18B1 block, B16 head and B18B1 head gasket and I have no leaking issues.
Old Apr 19, 2012 | 10:05 PM
Originally Posted by nealnanoHX
If done right that is= no issues.
There wasn't a person in 200 miles of where he lived that knew anything about hondas plus he was turbo'd. Blew three motors before he sold everything.
Old Apr 20, 2012 | 07:00 AM
boosted_D's Avatar
Sleeved B20 block and gsr head FTW!
Old Apr 20, 2012 | 07:10 AM
nealnanoHX's Avatar
That is what a phone and these forums are for. A 10 second search will find you all the info you need on doing a B20 or Ls Vtec right.
Old Apr 20, 2012 | 07:16 AM
Hidenplanvew's Avatar
Just do a GSr block with LS crank, just have everything balanced and you wont have a problem.
Old Apr 20, 2012 | 07:40 PM
DirtyDA9's Avatar
Put the $350 towards sleeving the LS. Unless you plan on constantly revving the **** out of it, don't bother with a girdle. But if you feel the need, get a KRL or something, and you will need ARP's and machine work to make the girle work with the main caps.
Old Apr 20, 2012 | 07:47 PM
Turbo-LS's Avatar
LS crank GSR block ftw
Old Apr 20, 2012 | 08:58 PM
egRexBswap's Avatar
X2^^^ best of both worlds.
Stopsign32v
Feb 22, 2016 03:35 AM
butterbeer2fd
May 18, 2012 09:39 AM
ten_30
Aug 9, 2002 07:44 AM
