How to rebuild TD-05H Link.
I recently acquired a Greddy TD-05H 18G turbo and came across this link.
http://www.mitsu-media.com/showthread.php?t=9948
I thought it was worth sharing for those interested in rebuilding their turbo's.
Re: How to rebuild TD-05H Link.
That's all fine and dandy, But where does it account for balancing the turbo? It doesn't, because you cant do it on your own, a pro has to do it.
If your lucky 1 in 100 turbos might turn out to be balanced enough with no proper balancing job and will work fine, the other 99 will self destruct in a matter of no time because they are not balanced.
You know how a motor revs to lets say 7000 to 9000 rpm, and the crank/rods/pistons (mostly the crank) have to be properly balanced or the motor will self destruct...
A turbo spins at 200,000+ rpm, in no way is it ok for it to be off balance by even a tiny bit.
Moderator
There are also a few points in the below link about balancing. Are they true?
http://gpopshop.com/services/turbo-balancing/
Freshdot
08-21-2011 07:07 PM
