difference between turbos
Old Mar 28, 2012 | 06:26 PM
HatchVX's Avatar
Default difference between turbos
I have a t3/t04e 60 trim that came with my Peakboost kit, that i had rebuilt and decided to take a ****. How would the Roto-Master 60-1 t3/t4 compare to it?
Old Mar 28, 2012 | 06:51 PM
TheShodan's Avatar
Moderator
Default Re: difference between turbos
Like any other 60-1 that uses a stage 3. Not much more power than your 60 trim, and its only in the top end. Larger compressor wheel and housing allows for slightly larger top end, but less response.
Plenty of other turbos out there, can't say which is "best" until you start going for particular goals, power levels, use of the car and budget. maybe its best to just get another 60 trim.
Old Mar 28, 2012 | 07:26 PM
HatchVX's Avatar
I found someone selling one for 200.that's why I was asking. I'm looking for around 400hp. I'm running a GSR block sleeved to 84.5 mm. Weisco pistons (9.0:1) eagle rods and a type r crank. I have a b16 head. Trying to figure out if I should go with my GSR or b16 cams.
Old Mar 28, 2012 | 07:33 PM
TheShodan's Avatar
Moderator
Stay with your GS-R camshafts. 400whp can be found in that turbo, but for 200 bucks that tells me something may be wrong with it requiring a rebuild. I'd ask questions about it first.
Old Mar 29, 2012 | 06:17 AM
nealnanoHX's Avatar
Plus1
Old Mar 29, 2012 | 06:38 AM
boosted_D's Avatar
yeah.....$200? sounds fishy.....You could find a nice holset turbo for like $350, or go for a new precision 6031 for $600
kebroz
Dec 4, 2008 07:16 AM
pjhatchin
Jul 25, 2005 08:11 AM
toxicshit
Oct 30, 2003 01:36 PM
frogscivic
Apr 21, 2003 06:58 AM
