d16z6 t3t4 turbo ?
d16z6 t3t4 turbo ?
ok so im looking in to getting a 94 civic d16z6 with a t3t4 turbo running a 8 psi
i know that a d16z6 should have a p28 computer but it says this 37820-p09-a00
does anyone know what it is and if i need to get a flashed p28 for turbo?
Re: d16z6 t3t4 turbo ?
it has two step on it in but someone set it at 3 grand so idk
im kinda new in to this honda world. real American muscle is bad *** but super expensive and im intrigued by these small engines making big numbers for the low
so what psi should that turbo be running at
Seagull Management
I'm guess that actually said P06. You can chip and convert P06s to vtec. They use the same board as a P28 without the vtec components (which can be added) And yes once chipped it doesn't matter what it was orginally for. There's a few guys running toyotas and nissans on P06s using Honda distributors.
OBD1 USDM P09-A00 Civic DX D15B7 SOHC
OBD1 USDM P06-A02 Civic DX D15B7 SOHC
OBD1 USDM P09-L00 Civic CX D15B8 SOHC
(same as P05)
OBD1 USDM P05-L01 Civic CX D15B7 SOHC
(same as P05)
