turbo crx 1.6 lean.
turbo crx 1.6 lean.
i just turbo'd my crx 1.6 its stock i was wondering if i can use stock injectors on with a chipped p06 to compensate for it running lean or do i need to buy different injectors like 360cc's? Cause i have a wideband and a active pyrometer to tune the wideband shows lean and the exhaust temps go outtof control so def lean.
Re: turbo crx 1.6 lean.
Ok so you turbo'd your CRX and did not know you need to upgrade the fuel system??? What are you doing with a turbo on the car then! Let me guess it is a Chinese Ebay turbo kit? Yeah get some DSM 450's and a 255 Walbro fuel pump and go to the dyno for some tuning. Oh you will need a OBD1 ECU that is chipped with something like Crome which is cheap and works for tuning. A PO6, P28 or OBD1 P75 will all work.
i have a p06 ecu and im chipping it myself this weekend so i got that covered i only plan on running 8 lbs so will i need 450's or will the 360's work? and i just picked up a walbro from my friend today, who also has the 360's.
