Voltage drop after walbro 400 install?
Old Apr 9, 2012 | 05:49 PM
Laojoeturbo's Avatar
Default Voltage drop after walbro 400 install?
After I install my Walbro 400 my voltage drop while driving from 13.8-13.9 to 12.9-13.0. I am wondering if this is normal for the guys that has ran this pump before? Is it going to affect my power or anything? Car runs good and sounds good but my tune date is coming up in a week so I just want to get it ready. Thanks
Old Apr 10, 2012 | 04:06 AM
Default Re: Voltage drop after walbro 400 install?
No one ?
Old Apr 10, 2012 | 05:16 AM
Turbo-LS's Avatar
Sounds like the voltage regulator in the alternator isnt working correctly. i cant say for sure because im not running he walbro 400 but I do know the voltage output of the alternator should be 14.3-14.7 Is this just at idle your experiencing sucha drop or even while crusing ?
Old Apr 10, 2012 | 06:05 AM
This is while i'm cruising. Is this going to affect how my car performs?
Old Apr 10, 2012 | 01:45 PM
Up
Old Apr 10, 2012 | 03:03 PM
Turbo-LS's Avatar
sounds like a bad alternator or the alt control in the ecu isnt working correctly. In my personaly car i would only get 13.2-13.6 voltage and i tried three different alternators, swapped out ecu and voltage went up to 14.7.
Old Apr 10, 2012 | 03:19 PM
Hrmmmm that is really weird. I'm going to try swapping in a new alternator to see if it solves the problem.
Old Apr 10, 2012 | 03:28 PM
Turbo-LS's Avatar
if ALT doesnt fix it then swap out to a known good ecu if you have available. i had several laying around and just setup a new one to run with my hondata and found that fixed it
huge230
Aug 22, 2008 08:28 AM
burgertime32
Mar 29, 2008 04:00 PM
firstgenrex
Oct 19, 2003 12:02 PM
The Poopsmith
Audio / Security / Video
13
May 7, 2003 11:26 AM
88 rex
Mar 14, 2003 10:47 AM
