First fire on turbo build, it ran! Now issues
Old Apr 7, 2012 | 11:54 PM
TravisBiggie's Avatar
Default First fire on turbo build, it ran! Now issues
I turned it on for about a minute, turned it off. started it again for 30 seconds, turned it off, and when trying to start it the third time, the hazards were flashing, as well as the interior lights. When I would turn the key in the ignition, it wouldnt start, but the lights would dim a little. Has anyone had this issue before? I disconnected the battery for over an hour and tried again, same issue. my 02 sensor on the downpipe is not installed.
Also, my turbo sits so low that I barely had the oil return feed hook up to the oil pan, anyone have ideas on another return set up instead of this return line here?
http://www.ebay.com/itm/Turbo-Oil-Re...4147de&vxp=mtr
Also, what lines here are vacuum, where should I connect my BOV to?
Old Apr 8, 2012 | 04:10 AM
SiRCiviC94's Avatar
Default Re: First fire on turbo build, it ran! Now issues
Connect it to the brake booster
Old Apr 8, 2012 | 07:39 AM
Is that the oil catch can looking thing next to the battery and passenger side firewall?
Old Apr 8, 2012 | 08:50 AM
SiRCiviC94's Avatar
the fuel filter?
Old Apr 8, 2012 | 09:27 AM
Next to the fuel filter too
Old Apr 8, 2012 | 09:48 AM
Whiterice-gsr's Avatar
dude if u dont know where your brake booster line is this is going to be very difficult to diagnose. second your turbo should have nothing to do with electronic systems so id say your no start is an unrelated issue. third show some pics of the turbo drain line. fourth why would u not put the o2 sensor in. and fifth how are u feeding the turbo with oil.
Old Apr 8, 2012 | 09:55 AM
Freshdot's Avatar
if you don't know what a brake booster is, you probably shouldn't be doing any of this yourself.
Old Apr 8, 2012 | 02:44 PM
if the brake booster/brake master cylinder are the same.. I got it. But there are no vacuum lines connected to it.
The car is running now, the battery pussied out on me, idk why. Anyways everything is up and running now, just gonna re install the turbo, downpipe, rest of the exhaust, and I'm good
Old Apr 8, 2012 | 05:30 PM
oh boy, the brake booster line goes to the brake booster it is the big fat line that u painted green for some reason, use that to tee into for your bov.
Old Apr 8, 2012 | 07:03 PM
purchased the car with the shitty paint job, dont hate. once the car is running properly I'm gonna respray it black so it doesn't look like complete ****
Old Apr 8, 2012 | 07:04 PM
that line is HUGE? much larger than my bov tube..
Old Apr 8, 2012 | 07:30 PM
lol tee off it for your bov, wastegate (if turbo doesnt have a nipple on the cold side) and your boost gauge. the only other better way is too tap your manifold and have dedicated lines.
ek98gsr
Feb 6, 2015 10:56 PM
FuzyNavel
May 8, 2011 06:15 PM
MAFDARK
Nov 20, 2007 09:03 AM
TurboedGSR
Sep 28, 2003 08:23 PM
