ls turbo code 35? need help please
Old Apr 1, 2012 | 11:08 AM
inovative91's Avatar
Default ls turbo code 35? need help please
ls turbo tuned on chrome. 19psi made 301whp friday on the dyno. cel came on and is showing code 35. obd1. i have looked all around and can not find such a code. some one help me. also i have already tried changing ecu's still shows same code
Old Apr 1, 2012 | 02:12 PM
dpetro1's Avatar
Default Re: ls turbo code 35? need help please
no such thing as code 35. you must be reading it wrong.
30 is automatic transmission so that doesn't make sense. code 5 is MAP. pull the code again.
Old Apr 1, 2012 | 05:49 PM
I've been in this game for 7+ years it's code 35 that's the only reason I'm reaching out to you all, I'm stumpt. 3 long flashes and 5 short. The closest code to that is 36 which I know is only hem ECU equips with traction controll. I've tried to use a diff ECU but same code. Anyone else?
Old Apr 1, 2012 | 08:55 PM
jbpnoman's Avatar
Code 35 actually DOES exist with Chrome. It means your tune is messed up. Get a new chip, burn a fresh tune to it, and make sure you seat it properly.
Old Apr 1, 2012 | 09:04 PM
Dc4LsTeG's Avatar
EK9
It usually means the chip was installed wrong
Old Apr 2, 2012 | 05:43 AM
dpetro1's Avatar
damn, thanks for the info. i learned something
Old Apr 2, 2012 | 06:24 PM
So I should just ask my tuner to burn the map on a new chip?
Old Apr 21, 2012 | 03:01 PM
New chip didn't fix my issue..
eg_gsr11
Nov 18, 2006 05:48 PM
Jeef
Dec 9, 2001 06:35 PM
