please help with vacuum/boost lines for hondata boost controller
Old Apr 15, 2012 | 03:34 PM
protopro88's Avatar
Default please help with vacuum/boost lines for hondata boost controller
Im in the process of hooking up my boost controller and im alittle confused on the routing of the lines. Is everything hooked up correctly in the picture i have taken? Then do i just put another tee fitting on that same line going to the turbo compressor housing? Any help would be greatly appreciated! Thank you.
Old Apr 15, 2012 | 03:42 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: please help with vacuum/boost lines for hondata boost controller
Maybe once we get a picture. Your boost gauge should go off the intake mannifold and not the compressor housing.
Old Apr 15, 2012 | 03:47 PM
2000GSRTypeR's Avatar
http://www.xenocron.com/install/PWM-...00-neptune.htm
Here you go sir.
Old Apr 15, 2012 | 03:53 PM
What i need to know is which wire goes to ECU(A11) and which wire goes to fused 12V power source. I bought my MAC solenoid used and I can not seem to tell the difference in wires as they do not appear to be marked.
Old Apr 15, 2012 | 05:06 PM
protopro88's Avatar
I believe it doesnt matter which wire goes to A11 or 12v
Old Apr 15, 2012 | 05:08 PM
protopro88's Avatar
I know the boost gauge is suppose to go off the manifold. My question is do i cut the line that has a tee fitting in it already and put another tee fitting in so i can run a line to the compressor housing? Sorry if i wasnt clear enough
Old Apr 16, 2012 | 09:35 AM
protopro88's Avatar
The line going off the picture on the bottom right hand corner is going to my intake manifold. Can i just put that line to the compressor housing of the turbo instead?
skaraider
Jun 6, 2012 03:26 AM
standbackimapro
May 30, 2006 05:22 AM
marcussmith26
May 15, 2006 06:06 AM
ebpcivicsi1234
Feb 11, 2005 06:12 AM
azulito
Apr 5, 2004 12:16 PM
