b18b1 turbo stock motor, thinking about installing block guard?
Im going to be pushing about 250 to the wheel soon and I was thinking of installing a block guard.. Would it worth the labor to install it? If so, what else could I do to the motor while its ripped apart? Not trying to spend a lot of money currently, I am trying to save up to build a sleeved block with rods pistons..
So should I just keep it as is, or install the block guard? if the block guard alone is 100% worth all the labor and to help my sleeves from cracking.. i'll do it.
Thoughts?
Thanks
Thoughts?
Thanks
Re: b18b1 turbo stock motor, thinking about installing block guard?
the blockguard isnt even worth considering, it can only hurt things
i would get some head studs
i made 266whp with ge head studs and NO blockguard
write up/benefits of headstuds? I have a general idea but I want a more detailed outlook
head studs makes it so the head wont lift like you can get with stock head bolts, just not sure what the whp or psi limit is with stock head bolts
Block guards do absolutly nothing to help the sleeves not crack. stock sleeves can take 400-500 reliably. 250 is nothing. just geta good tune because even at 250 with a bad tune sleeves will crack
http://www.b20vtec.com/forums/engine...rt-system.html
This machined support looks pretty sweet. Far better than your typical blockgaurd.
It's installed via precision CNC. (i.e No hammering involved lol)
It's an aluminum insert, so you retain decent heat dissipation. People claim that these cause overheating... but what's the difference between this and a full-blown iron sleeve??? If anything, it would cool better than iron..
I'll finish all that by saying.... 250whp doesn't require any blockgaurd/support etc. Just a need process I thought I'd mention.
12-08-2004 04:09 PM
