injector help
Old Apr 13, 2012 | 09:42 AM
vtexas936's Avatar
Default injector help
Stock jdm b16 with ls tranny. Daily driven and not looking to make huge power numbers since its my daily. Anyone else with stock b16's boosted what injectors are you running and how many pounds of boost?
Old Apr 13, 2012 | 10:23 AM
boosted_D's Avatar
Default Re: injector help
yes it can and has been done about a million times, forget about psi, it's all about a horse power goal, at or under 300 should be your goal......Do some more research then come ask real questions....
Old Apr 13, 2012 | 11:09 AM
vtexas936's Avatar
I didn't ask if it can be done. I know it can. I asked what are good injectors for daily use along with a good psi number. Nowhere did I say can you boost a stock b16
Old Apr 13, 2012 | 11:16 AM
rich7777's Avatar
Here you go:
http://lmgtfy.com/?q=good+injectors+honda+tech
or
Old Apr 13, 2012 | 12:01 PM
TheShodan's Avatar
Moderator
I would love to know how you do that... I've been dying to try that out for weeks.
Old Apr 13, 2012 | 12:10 PM
rich7777's Avatar
http://lmgtfy.com/?q=let+me+google+that+for+you
Old Apr 13, 2012 | 12:14 PM
boosted_D's Avatar
Ok smart guy.....well if you knew about how turbo stuff works, you would realize that psi is irrelevant, what matters is horse power, you can run 20 psi on a t25 and make the same power by running 8 psi on a 57 trim....and injector size also depends on Horse power, injectors have the ability to provide enough fuel for any given set up depending on how much power it makes....so as I said, do some god damn research then ask some real questions
Old Apr 13, 2012 | 01:17 PM
rich7777's Avatar
Here you go... http://letmegooglethat.com/?q=turbo+psi+is+irrelevant
Old Apr 13, 2012 | 04:33 PM
EsotericImage's Avatar
Retired Moderator
since im in a good mood, Taken from Jeff Evans Tuning
Below is a quick guideline for injector to power rating given a base fuel pressure between 40-50psi:
240cc/min (stock): 170-180whp
310cc/min: 200-240whp
370cc/min: 250-275whp
440cc/min: 300-325whp
550cc/min:350-375whp
650cc/min: 400-425whp
750cc/min: 450-475whp
1000cc/min: 600whp
1200cc/min: 700whp
1600cc/min: 850whp
88 EF Hatch
Jul 30, 2011 09:51 PM
cryoman999
Apr 3, 2009 08:17 PM
sfwdcrx
Dec 20, 2007 09:21 AM
blackcrx16
Jul 23, 2007 04:41 PM
AJxr
Feb 5, 2006 09:03 PM
