Need Help setting up EBC
Old Mar 31, 2012 | 02:31 PM
Infamous war's Avatar
Default Need Help setting up EBC
Hey fellas, This might be a dumb question but i am having trouble figuring out how to setup up my greddy profec spec b 2 boost controller. I have a -00 civic si, I have my boost gauge t fitted at the fuel pressure regulator. So i am trying to figure out how to hook my mvs wastegate up along with my bov and boost controller to a vacuum source. I know wastegate has hose going into boost solenoid then coming out from other side of solenoid i was going to run hose to T fitting that would also have the 4mm hose coming from the actual boost controller from inside the cabin. The boost source that i was going to use for that setup was from the cruise control vacuum line from back of the intake manifold.
With all that being said and hopefully not confusing. Where do i get the vacuum source for the bov? Also am i setting everything up correctly? This is my first time boosting a car and i am just trying to make sure i run everything right..
Good feedback will def be appreciated
Thanks in advance
Old Apr 1, 2012 | 02:21 PM
dpetro1's Avatar
Default Re: Need Help setting up EBC
boost controller gets connected as follows:
top port of WG -> COM on solenoid
NC -> turbo compressor hosuing (boost signal)
NO port left open (or filtered)
do you have the manual for the EBC? if not greddy has it on their website
http://www.greddy.com/upload/file/PRofec_Bspec2.pdf
as for your other vac sources, you can run a vacuum block to get more ports or tee into other sources.
RNPoo7
Apr 8, 2005 06:33 AM
elpiar
Mar 21, 2005 09:09 PM
importboi22
May 20, 2004 04:43 AM
It's*BOLO!!
Apr 10, 2003 07:54 PM
