Block guard, yes or no??
Old Apr 17, 2012 | 10:03 AM
MikeyL513's Avatar
Default Block guard, yes or no??
I have a turbo gsr im in the process of building. Going to be forged bottom end and im debating on using a block guard with it. Any problems, personal experience. Only shooting for around 350ish whp. Thanks
Old Apr 17, 2012 | 10:13 AM
97_coupe's Avatar
Default Re: Block guard, yes or no??
Put the money towards a good tune instead, even at ~350WHP, people have done that on stock internals.....Tune is key
Old Apr 17, 2012 | 10:14 AM
rich7777's Avatar
http://lmgtfy.com/?q=block+guard+honda+tech
Old Apr 17, 2012 | 10:18 AM
Dc4LsTeG's Avatar
EK9
No
Old Apr 17, 2012 | 10:21 AM
boosted_D's Avatar
Hell NO on the block gaurd, causes way more problems than it attepmts to help with....350 whp on stock sleeves is well under what stock sleeves can handle....
Old Apr 17, 2012 | 10:23 AM
rich7777's Avatar
How many times has this been asked?
Old Apr 17, 2012 | 10:33 AM
LS AzZkIkr's Avatar
https://honda-tech.com/forums/drag-racing-36/cncwerx-css-block-cut-half-3042021/
That is the closest thing to a "blockgaurd" I would ever use!
Old Apr 17, 2012 | 12:43 PM
MikeyL513's Avatar
My bad, i used the search on HT instead of google and didnt come up with anything earlier. Been looking thru the threads and have made up my mind that im not going to use one.
Old Apr 17, 2012 | 12:57 PM
Boostage's Avatar
He didnt even say what motor, last time I was active on these forums the consensus was b20 sleeves were ****, Do people still feel the same?
Old Apr 17, 2012 | 01:18 PM
Turbo-LS's Avatar
b20 sleeves will handle 350-400 but there is very little material between the cylinders which is the failing point.
Old Apr 17, 2012 | 05:08 PM
dantamparacer's Avatar
No block guard, all it will really do is create a hot spot in the cylinders and with the cheap ones restrict coolant flow. I know of several stock internal gsr motors that made over 350whp. I personaly would run stock internals and save for sleeves. But just my .02
Old Apr 17, 2012 | 05:57 PM
MikeyL513's Avatar
I already said its a gsr, and the motor is already completely disassembled and im not gonna waste my time putting cast pistons back in it. Plus i already oreder most of the parts
Sgtschif
Dec 29, 2013 01:12 AM
93gsr4dr
Feb 18, 2010 06:36 AM
beyondstock
May 8, 2009 07:04 PM
marksturboek
Apr 23, 2006 03:02 PM
BLKCRX
Apr 5, 2002 09:18 AM
