Question reguarding turbo build. -ARP head/main studs
Hi guys.
Basically I am in the process right now of rebuilding my ls motor for turbo in the future. I am down to the last few things to buy before I can start assembling!!! I am shooting for 350 whp with my set up. Nothing to crazy for now.
Two questions:
1. Do I need to buy both ARP main studs AND headstuds?
2. What rebuild gasket kit is good for a total rebuild. I just need a kit that has the gaskets that I need. I do not want to buy off ebay unless you have a recommendation on that.
One set that I have found is this one:
http://www.autopartsway.com/PartList...ead_Gasket_Set
And there is another set similar containing the oil pan gasket and what I assume are the pump rings. Total for the two is a little over 200 bucks.
I have learned a lot off this forumn and for that I thank you. Any comments appreciated. Thanks
Two questions:
Re: Question reguarding turbo build. -ARP head/main studs
OEM head gasket is best. Get ARP head studs. DO NOT get ARP main's, not worth the machining involved to make them work.
Not to hijack, but I used ARP main studs and the only modification I had to make was with the windage tray?
i think its one of those things where sometimes when using arp mains you have to line hone cause sometimes it goes out of round im just guessing
Ok thanks guys. I was thinking that main studs were a for sure that I needed. What other brand do I get?? If it's only small modification that I need to do to use them then I will do that.
Cap'N Chronic
10-16-2011 06:47 AM
Dontoh
10-13-2010 07:59 PM
