GSR turbo problem
Old Apr 1, 2012 | 02:19 PM
dotasefu's Avatar
Default GSR turbo problem
I have EG civic with a stock GSR and I just recently install at turbo kit. The car ran fine while N/A but ever since I install the turbo kit It barely wants to start. I pull out the spark plugs and they look pretty damn dark and gas up. It's also throwing me a CEL 7, but I replace the TPS sensor and recalibrate it; still throwing me that code again. I check the timing, Resistor box wiring, dsm 450cc and ground eveything looks properly install. As for right now I'm running Crome with a Xenocron basemap at the bin.files. call "final.bin" Let me know if any HT members have a similar issue with this. thank you
Old Apr 1, 2012 | 02:24 PM
dpetro1's Avatar
Default Re: GSR turbo problem
probably has nothing to do with the turbo. you need to fix the code 7, which you already have a thread on. no need for two
Old Apr 1, 2012 | 04:33 PM
dotasefu's Avatar
I dont have CEL 7 at the moment, but my car sputters and dies with the original connector. I also have a tps sensor that is connected to the A7 GRN/YEL FLR1 fuel pump, B12 WHT CYP M CYP -M, and D21 GRN/BLU SG1 MAP GND that apparently works. If your asking me I dont know why...Help
Slammd Sol
Sep 1, 2014 06:29 AM
delslow45
Apr 26, 2011 12:37 PM
SOHC_Brian
Sep 24, 2005 08:32 PM
ryan89crx
Jul 18, 2005 08:15 PM
Slammd Sol
Mar 13, 2005 10:10 AM
