Vortech
Old Mar 29, 2012 | 03:41 PM
Stevan22's Avatar
Default Vortech charger on civic info needed please
Any of you guys running vortech chargers?
Was wondering how to make more boost? I'm running the HO with after cooler on a 99-00 civic si, and don't even know what the standard psi boost is
And any maintance required like oil ectr.?
How does the after cooler work?
Thanks
Last edited by Stevan22; Mar 30, 2012 at 07:39 PM. Reason: More info on the thread
Old Apr 1, 2012 | 02:44 AM
Stevan22's Avatar
Default Re: Vortech
Nobody running vortech?
Old Apr 1, 2012 | 04:10 AM
cleansi's Avatar
Default Re: Vortech
they are pretty out dated its more of a VW thing.
there is not to much power or aplications for them
Old Apr 8, 2012 | 06:01 PM
creativejustin's Avatar
Default Re: Vortech
hey man im running the same set up... Hit me up and we can talk. Its so rare to find someone that has this kit
Old Apr 8, 2012 | 06:14 PM
sanman000719's Avatar
Default Re: Vortech
thats because you can turbo for cheaper, and make alot more power
Old Apr 8, 2012 | 06:48 PM
TheShodan's Avatar
Moderator
Default Re: Vortech
well, the VORTECH was never that popular compared to Oscar Jackson's setup due to cost, design and the simplicity of installation of the JRSC. The Vortech was usually about 30% more expensive when they came out with the system in 2002, compared to the JRSC from 1998 and beyond. They used Vortech and NOVI systems that were interchangeable, (if you knew what to look for), but maintenance was rather a PITA because of lack of parts availability, and the high cost of replacement parts. When they first came out they were already over $4K, and though it used a centrifugal charger, similar to a turbo, it didn't allow a lot of Comforts that that JRSC did, like A/C, Power steering,etc.. and it was a tight squeeze
Kudos for you to try and start a discussion on it, it will be few and far between, but I wish you well.. What a trip down memory lane..
Old Apr 8, 2012 | 06:58 PM
Default Re: Vortech
thats true... Turbo is the way to go if u want high hp numbers... BUT the fact that my kit is so rare makes up for all the other bull ****. And I still have A/C and Power steering.
Old Apr 8, 2012 | 07:54 PM
TheShodan's Avatar
Moderator
Default Re: Vortech
As do today's turbo options. Being rare can be an advantage, and a disadvantage at the same time. Such as replacement components.
Old Apr 8, 2012 | 07:58 PM
digital sol's Avatar
Default Re: Vortech
Any questions other than just how to make more boost?
Boost levels depends on 2 things with the vortech. Size of the crank pulley and size of the vortech pulley. Bigger the crank pulley the more boost you will make. CRV crank pulley is the largest Oem pulley available. You can also get a smaller vortech push to make more boost. Smaller the vortech pulley the more boost you can make. With the smallest vortech pulley and CRV crank pulley you should be at aprox 15psi. Anything more than that and youll need a custom pulley to run a wider belt to avoid slippage.
Btw I'm writing this from my phone so ignore the typos.
As for the power cooler it allows water to run through the cooler as air passes through this cooling the air as it enters the engine. Basically its their version of an air 2 water intercooler. It's another way to cool the charge this making more power and keeping intake air temps down. I had the kit but never ended up having it tuned....decided to go for a full build but the quality of the kit was awesome. I was going to be shooting for 350whp on my setup but as mentioned never ran it.
Old Apr 8, 2012 | 08:10 PM
TheShodan's Avatar
Moderator
Default Re: Vortech
Don't forget size of the compressor wheel in centrifugal system..that makes an even bigger difference than just crank pulley.
Old Apr 8, 2012 | 08:20 PM
Default Re: Vortech
Im making 336 right now on 15 psi
ran out of fuel and my exhaust is to small... 2.25 is killing me and the 55cc injectors maxed out
Old Apr 9, 2012 | 07:17 PM
Stevan22's Avatar
Default Re: Vortech
No bickering please between turbo and supercharges ...it has been done...I think everyone for them self.....
Old Apr 9, 2012 | 07:19 PM
Stevan22's Avatar
Default Re: Vortech
we can talk...what is your set up making those figures...
Pm if you want
Old Apr 9, 2012 | 07:23 PM
Stevan22's Avatar
Default Re: Vortech
Thanks man...what size is the smallest vortech pulley? All the vortech products for 99-00 are discontinued.
If you put the crv pulley on it can you still use the original belt?
Old Apr 9, 2012 | 09:01 PM
Default Re: Vortech
3.12'. Yes that is true however that does not mean they are sold out of what was left in stock. I'd still call vortech or other dealers and see if the pulley is availible. The important part being the charger and driveshaft can still be rebuilt by vortech so no worrys there. As for the belt you'll need a different belt for sure, all you need to do is cut some string and wrap it around the pulleys, then measure it and buy a 4 rib belt in that length from autozone or oreilys. Gator makes a good belt. Post up results when your finished up!
Old Apr 10, 2012 | 03:58 AM
Stevan22's Avatar
Default Re: Vortech
It's not easy for me to find a shop who has custom fit belts...I'm from nothern Ireland I emailed vortech a few times now but no reply at all.
Old Apr 10, 2012 | 06:43 AM
boosted_D's Avatar
Default Re: Vortech
Yah you need different pulley's/belt to make more boost. That being said, judging by what you have said, you should be able to make more power without changing the boost pressure by doing a few other mods:
Open up you exhaust more, go 3" all the way from a good header.
Step up to larger injectors.
maybe add water/meth injection.
Take back to dyno for more tuning.
Just these things with your current 15 psi should give you a considerable gain in hp.
Also I didn't see if your on a stock internals motor or not?
If you are then going past the 336 your already making is a bad idea anyway unless you do built / forged internals, you will pop the motor....
Old Apr 12, 2012 | 06:29 PM
Default Re: Vortech
Heres my set up
Jdm Gsr
84mm Darton sleeves
Completely Stock head
Manley Rods
Wiseco 9.4 pistons
Crv Crank pulley
Vortech 3.12 4 rib Supercharger pulley
Makes 15 psi...
Old Apr 12, 2012 | 06:32 PM
Default Re: Vortech
Made 336 hp and 226 tq
That is a very safe tune and we still maxed out my 550cc injectors
More dyno time and bigger injectors and exhaust will push the numbers up
But ill prob built my head so I can turn more rpms before i get it retuned
Old Apr 13, 2012 | 05:33 AM
Stevan22's Avatar
Default Re: Vortech
Heres my set up
Jdm Gsr
84mm Darton sleeves
Manley Rods
Wiseco 9.4 pistons
Crv Crank pulley
Makes 15 psi...
Gsr head ? Is That 1.8 vortech set up?
I'm running
Benson sleeved
Pauter rods
Cp pistons
micro polished crank shafts
Stock b16 head
I need vortech 3.12 4 rib supercharger pulley anybody can help please
Old Apr 13, 2012 | 01:41 PM
Default Re: Vortech
I'm running
Benson sleeved
Pauter rods
Cp pistons
Stock b16 head
pm the vortech dealers on here & perhaps one will turn up
Old Apr 13, 2012 | 06:39 PM
Stevan22's Avatar
Default Re: Vortech
R there any on the forum ?I had a search but it seem all turbo apps.
Maybe I haven't search hard enough....
Old Apr 13, 2012 | 07:14 PM
Default Re: Vortech
www.assaultech.com
assultech is the HT username
Old Apr 16, 2012 | 05:36 AM
Stevan22's Avatar
Default Re: Vortech
www.assaultech.com
Thanks I try and have a look.
You running boost too? Any pics
Old Apr 16, 2012 | 05:37 AM
Stevan22's Avatar
Default Re: Vortech
Heres my set up
Jdm Gsr
84mm Darton sleeves
Manley Rods
Wiseco 9.4 pistons
Crv Crank pulley
Makes 15 psi...
Any pics of the engine bay?
