1in or 2in exhaust wrap
i have a log manifold that i want to wrap. i wanted to know it from ppl that have done it before if they used 1 in or 2 in wide wrap and my a pic of the finished product?
thanks
thanks
Re: 1in or 2in exhaust wrap
i would have to say 1"
i've wraped 3 or 4 downpipes with 2" getting it around those bends isnt hard but i wouldnt want to attemp anything with a tighter bend radius.... i plan on 1" if my ramhorn
and the trick to a nice tight wrap is to soak it in warm water first...it will slightly loosen up the fibers while wet and it will tighten back up as it drys
While this topic is up , what is the best way to clamp the wrap @ manifold...is there better way then using ugly *** hose clamps? maybe some sort of wire ties that doesnt look as bad.
Also soaking in warm water prior to adding the wrap seems like good logic
R.I.P. Mark
http://www.ebay.com.au/itm/10-8-Stai...item19cc4cc9ba
Wear gloves and make sure your skin doesn't make any contact with the wrap. That fiberglass stuff is no joke and will irritate the **** out of your skin. Just a heads up! I had to learn this the hard way!
FRKWOO
07-24-2009 11:17 AM
Spade
06-21-2002 09:54 AM
