I need help guys please
Old Apr 11, 2012 | 01:07 PM
brxboy's Avatar
Post I need help guys please
ok here is the set up b18b stock sleeves,stock head,golden eagle fuel rail,wiseco pistons 8:6.1 comp,mainly h been rods,precision 660cc injectors,walbro 255 pump,golden eagle block guard,It has A go autoworks turbo kit on it the turbo is A precision 54/31 billet cea t3t04e 63 AR.ok i got tuned and I only made 165 brake hp me and the tuner was like wtf is going on.we went over everything looking for boost leaks and all.He told me I might need A valve job or I might be geting valve float.so I drove home mine fuuuuccccckkkkeeeedddd with A slow car, thinking to my self like wtf could be wrong.I chilled for A bit let the car cool off went out side and started touching stuff And come to find out the bolts, that holds the turbo to the mani was so damn loose Im surprise the turbo didn't fall off.I tighten everything up And now It pulls like A bitch but Im geting boost cut At 5300.i know i need A re tune but Is it safe to drive, it back to the dyno shop or tow it.????????????????
Old Apr 11, 2012 | 01:13 PM
brxboy's Avatar
Default Re: I need help guys please
the new set up now as i was tuning i had this b/c u see in the bottom right hand corner hooked up its A js b/c.i showed my tuner this video and he told me i had it hooked up wrong cause my car boosted to 10 lbs and om on a 8lbs spring.i had it hooked up just like in the video.=( http://www.youtube.com/watch?v=hwsyR...3pMKTgNpDFvpVV
Old Apr 11, 2012 | 01:18 PM
da_dude's Avatar
Yes, it'll be fine to drive it back as long as you don't push it.
Old Apr 11, 2012 | 01:40 PM
brxboy's Avatar
ok man thanks alot as for the b/c does that look right to you the way he say to hook it up cause my tuner think other wise.idk if i should trash the b/c, all together and buy a name brand one or what.or should i give it one more try now that the turbo I tighten.?
Old Apr 11, 2012 | 01:56 PM
boosted_D's Avatar
Wow.......huge fail here man.......get it tuned again.
Old Apr 11, 2012 | 03:26 PM
Slacker93eg's Avatar
10 Year Member
The tuner didn't think to check that?? I'd think about who's tuning the car?
and just disconnect an intercooler pipe and you wont build boost
Old Apr 11, 2012 | 04:24 PM
brxboy's Avatar
the car is on 3 inch open mid dump, so Its really loud so it was hard to hear the huge exhaust leak.lol
Old Apr 11, 2012 | 04:29 PM
brxboy's Avatar
yeah man it was a really huge fail on my part.lol i was changing the turbo and i was between moving,so i got the car towed to the new house and for got to cheek everything.Well thanks guys for the help Ill have It back on the dyno next week.
Old Apr 11, 2012 | 04:30 PM
brxboy's Avatar
what does anyone think about the boost controller .????????
eg6islife
Dec 1, 2012 03:44 PM
JDeez_1212
Aug 26, 2012 12:34 PM
luvmihatch
Oct 11, 2007 03:07 PM
3k9civic
May 5, 2005 09:46 PM
bdicustoms
Aug 9, 2003 06:44 PM
