How to gap plugs
Old Dec 3, 2005 | 10:46 PM
fanta!'s Avatar
Default How to gap plugs
how do you make the gap smaller with the gapper? hit it against something? push it against something? everytime it gets to a smaller gap, when i check the new size it seems really easy to push it to a higher gap size, am i not doing it tight enough?
Old Dec 3, 2005 | 11:19 PM
komat's Avatar
Default Re: How to gap plugs (fanta!)
pushing it agaist something flat
Old Dec 3, 2005 | 11:38 PM
Westrock2000's Avatar
Default Re: How to gap plugs (komat)
I usually push against the driveway or a brick wall, because the coarse surface allows the ground tab to get wedged in and not slip. Some are easier to bend then others too. Cheap copper plugs are usually real easy, but I just put some NGK Iridium plugs in and I had to push pretty damn hard to bend the ground tab.
Old Dec 3, 2005 | 11:40 PM
Dunc's Avatar
BCICAN
tap the ground strap against a hard flat surface lightly...if it didn't reduce the gap hit it a little harder. Keep doing this until the gap gets smaller, but don't go for the gold the first time you do it.
Old Dec 4, 2005 | 07:05 AM
lsturbocivic4do's Avatar
I use chanel locks
Old Dec 4, 2005 | 08:41 AM
N20civicB18's Avatar
Default Re: How to gap plugs (Dunc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dunc &raquo;</TD></TR><TR><TD CLASS="quote">tap the ground strap against a hard flat surface lightly...if it didn't reduce the gap hit it a little harder. Keep doing this until the gap gets smaller, but don't go for the gold the first time you do it. </TD></TR></TABLE>
Old Dec 4, 2005 | 08:47 AM
93turbo16's Avatar
They make gapping tools. It makes this a little easier.
But in the end I always lose mine, so I use the ground anyway.
rdeezy78
Oct 2, 2007 05:17 PM
krazyhmongboi
Nov 4, 2006 03:54 PM
2quik
Jul 7, 2005 08:07 PM
nyo91
Jun 25, 2004 06:04 AM
rocket_R
Jun 26, 2002 07:07 PM
