spark plugs
Old Dec 1, 2005 | 11:56 PM
boosted-EG6's Avatar
Default spark plugs
hey guys does it really matter on the spark plugs you would use for boost
because i hear you need to use a colder plug if so what kind cause i only use denso or ngk but i generally use the denso iridiums and i would think those would be the best because i see car that make 600 hp and they use the iridiums as well
so to all the boosted guys out there just looking for advice on a plug to use and if it matter on a colder plug verses a hotter plug.
Old Dec 3, 2005 | 09:57 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: spark plugs (boosted-EG6)
i dont know if this will help, it is taken from sparkplugs.com.
An unaltered engine will run within the optimum operating range straight from the manufacturer, but if you make modifications such as a turbo, supercharger, increase compression, timing changes, use of alternate racing fuels, or sustained use of nitrous oxide, these can alter the plug tip temperature and may necessitate a colder plug. A rule of thumb is, one heat range colder per modification or one heat range colder for every 75–100hp you increase. In identical spark plug types, the difference from one full heat range to the next is the ability to remove 70°C to 100°C from the combustion chamber.
Old Dec 3, 2005 | 10:07 AM
Toda Party's Avatar
go to ur honda dealership
give them this number
98079-57148
2.xx per plug retail
u'll need to buy a box of 10... or 2 boxes to make it 5 sets of plugs
ngk bkr7e-11 i believe
Modified by Toda Party at 4:31 PM 12/3/2005
Old Dec 3, 2005 | 11:06 AM
tilt's Avatar
general rule of thumb is 1 step colder per 70-100+hp over stock.
sparkplugs.com - bkr7e or bcpr7es are good ones to start off with.
Old Dec 4, 2005 | 07:48 PM
Default Re: spark plugs (tilt)
hey thanks guy i gonna go to honda a see whats up.
turbosivtec
Sep 18, 2009 05:11 PM
imzjustplayin
Dec 22, 2008 01:01 PM
unknown2
Oct 10, 2006 11:59 AM
DEMNTD1
16
Jul 18, 2005 05:26 PM
acuraLSSE95
Jul 14, 2002 09:47 PM
