GSR Cams with LS/Vtec Turbo setup... yay or nay?
I bought a set of GSR cams for my b16 head..
What do you guys think, anyone notice a difference with them... I heard they are a pretty decent turbo cam for a b16 head...
OR am i totally out to lunch?
Any help would be nice
Re: GSR Cams with LS/Vtec Turbo setup... yay or nay? (Topdawgg)
You're right, they will provide a significant gain in boosted engines over the b16.
In terms of b-series vtec turbo cams, they are the best bang for the buck....ITR's are better but cost quite a bit more.
BTW you could have searched, this has been discussed numerous times.
Re: GSR Cams with LS/Vtec Turbo setup... yay or nay? (_gurusan_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by _gurusan_ »</TD></TR><TR><TD CLASS="quote">You're right, they will provide a significant gain in boosted engines over the b16.
BTW you could have searched, this has been discussed numerous times.</TD></TR></TABLE>
thanks man, i did read alot about it.. thats what made me finally decide to buy a set.. i was just throwin it out there to get actual confirmation from people that have done it
what do you suggest i do to my head when i go to put in the new cams.. ITR springs and retainerS?
the GSR cams? You don't need to do anything...unless you want to rev higher.
I don't see any point in installing an ITR valvetrain unless you have ITR cams as well.
ok, just checkin...
so, i dont have to do anything special.. new cams just replace the stock ones, thats it...
Re: GSR Cams with LS/Vtec Turbo setup... yay or nay? (5thgencivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5thgencivic »</TD></TR><TR><TD CLASS="quote">Get some adjustable cam gears too while you are at it if you have access to a dyno.</TD></TR></TABLE>
i already have a set of cam gears, and the valve cover is already cut...
Im gonna be tuning it on a dyno, so that will be done..
Push for ITR cams and aftermarket valvetrain. However GSR's should net more power over the B16's if you're on a budget...
Re: GSR Cams with LS/Vtec Turbo setup... yay or nay? (JDMisGOOD)
i have gsr cams in my b16 head lsvtec turbo. im glad i did them over the b16 cams. for the price its worth it. you will pick up good midrange and also high end
Tong.Y
04-08-2010 04:59 PM
bigislandc2
08-10-2006 01:56 PM
oldskoolracer
08-17-2005 10:11 AM
