car wont start, need help please
Old Dec 3, 2005 | 07:33 PM
krazn's Avatar
Default car wont start, need help please
hey guys,
i've been on the search for about an hour now, and have not found an answer yet....so im asking for help.
my car doesn't start, and i'm not getting any spark... but there's a bigger story behind it. I did a compression test. I did the usual steps before the test, take off the ecu fuse, take off fuel injector clips, take out all spark plugs, etc. I get 180 across the board, and i put everything back together. my friend sits in the car and puts it in gear. Me, not knowing, i start the car and it jumps a few feet and the car shuts down. I then throw the car back in neutral and try to start the car, and nothing happens. my fuel pump is priming, i think i'm getting fuel cause i smell it. I checked for spark, and i'm not getting anything. What do you think happened? did the launch knock my timing out of place? or is my distributor crapped out? its getting late, and its really cold out, so i came inside to get some answers. Please help! i'm lost
Old Dec 3, 2005 | 07:51 PM
elpiar's Avatar
Default Re: car wont start, need help please (krazn)
trace the ignition from the wires to the distributor cap and rotors
maybe wait few minutes and try it again? main relay?
Old Dec 3, 2005 | 08:01 PM
krazn's Avatar
Default Re: car wont start, need help please (elpiar)
checked main relay. Car was running perfect before compression test. im wondering if the car can jump timing off that wicked launch when i thought the car was in neutral?
Old Dec 4, 2005 | 03:11 AM
CiViC SiR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krazn &raquo;</TD></TR><TR><TD CLASS="quote">checked main relay. Car was running perfect before compression test. im wondering if the car can jump timing off that wicked launch when i thought the car was in neutral? </TD></TR></TABLE>
no it wont
i think its from the coil inside the distributor, try to replace it.
Old Dec 4, 2005 | 06:59 AM
krazn's Avatar
Default Re: car wont start, need help please (CiViC SiR)
thanks alot...ill try the coil today. i just didn't see why the car would jump after the the compression test...which is a sign the car was gonna start...so the coil wasn't bad at the time? i'm confused?
Old Dec 5, 2005 | 12:08 AM
CiViC SiR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krazn &raquo;</TD></TR><TR><TD CLASS="quote">thanks alot...ill try the coil today. i just didn't see why the car would jump after the the compression test...which is a sign the car was gonna start...so the coil wasn't bad at the time? i'm confused? </TD></TR></TABLE>
the car jumped becuase of the strater
Old Dec 5, 2005 | 01:01 AM
lucidvtec's Avatar
car moved because of the starter...i would check all ur connections first...something is probably unplugs...or maybe a bad fuse....check it out with a DMM...before u start replacin stuff
Old Dec 5, 2005 | 09:29 AM
krazn's Avatar
Default Re: (lucidvtec)
thanks for the reply guys...i fixed the car last night. it was the coil in the distributor. i guess i burnt it out during the compression test.
by the way... civic sir...where did you get that bad *** batman icon?
Old Dec 5, 2005 | 09:41 AM
DriveSlowHomie's Avatar
Default Re: (krazn)
exact same thing happened to me a few weeks ago...my coil burnt out from doing a compression test...next time you do it unplug the wires to the distributor just for extra safety...
Old Dec 5, 2005 | 10:02 AM
krazn's Avatar
Default Re: (cmGSR916)
yeah dude, definately. i've done compression test like hundreds of time before....and finally messed this one up by not unplugging the wire....that or the distributor was already on its way to death....and i kinda pushed it over the edge.
boostedcivichatchbacksi
Aug 21, 2021 10:38 AM
ORguy
10
Mar 22, 2011 05:25 PM
McLovin
25
Nov 5, 2009 10:44 PM
stunt_driver
Jun 8, 2005 04:55 AM
KNO3
Jun 9, 2003 04:43 PM
