How to set my wastegate to my desired psi?
Ok i have a garret airsearch turbo i have started installing last night and i was wondering is there a way i can set to turbo to about 7psi or so..My ? is how do i set it?
I will be setting up my boost guage, air/fuel guage, fmu any ideas on how this is all set up.. thanks..
Re: How to set my wastegate to my desired psi? (seeeya04)
Unless you have a boost controller you can't adjust the boost. The boost amount will be whatever spring you have in your wastegate.
Re: How to set my wastegate to my desired psi? (crex23)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crex23 »</TD></TR><TR><TD CLASS="quote">Unless you have a boost controller you can't adjust the boost. The boost amount will be whatever spring you have in your wastegate.</TD></TR></TABLE>
i agree
i agree
b20vtech
01-24-2008 05:55 PM
