LS crank in a B16 block
Old Dec 3, 2005 | 07:44 AM
Forrest Gump 9's Avatar
Default LS crank in a B16 block
Just a quick question. Have anyone run a LS crank, LS rods, and custom pistons in a B16 block? As of in boosted application, I know there are people that do this in NA, but haven't heard of anyone running in boosted. Any problem do I have to look out for. And no, I don't want to run a deck plate either. Thanks
Old Dec 3, 2005 | 09:01 AM
Boostage's Avatar
Default Re: LS crank in a B16 block (Turbo9Nut)
U would need a deck plate, would be far cheaper to just buy a LS bottm end.
Old Dec 3, 2005 | 09:53 AM
tokesGTR's Avatar
Default Re: LS crank in a B16 block (Boostage)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostage &raquo;</TD></TR><TR><TD CLASS="quote">U would need a deck plate, would be far cheaper to just buy a LS bottm end.</TD></TR></TABLE>
He doesn't need a deck plate, the Tech43 setup runs LS crank/LS rods with a custom piston with an uber-high wristpin and it does work.
I feel if you want to use an LS crank in a B16 block the only way to fly is with B16 rods, with the LS rods your piston pin is totally intersecting the oil ring and all the tech43 built strokers were having oil control issues. If you think B16 rods + LS crank is a no-no, please consult sig
Old Dec 3, 2005 | 10:58 AM
Default Re: LS crank in a B16 block (tokes1320)
What?? Correct me if I'm wrong, but isn't b16's rod longer than LS's rod??
Old Dec 3, 2005 | 11:19 AM
tokesGTR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo9Nut &raquo;</TD></TR><TR><TD CLASS="quote">What?? Correct me if I'm wrong, but isn't b16's rod longer than LS's rod?? </TD></TR></TABLE>
Nosir, B16 rods are 5.290" long and the LS rods are 5.394" in length.
Old Dec 3, 2005 | 04:02 PM
m R g S r's Avatar
custom pistons would still be needed..correct?(for ls crank in b16 block with b16 rods)
NACvicSi
Apr 5, 2007 04:22 PM
JDMlyfestyle
Sep 27, 2004 02:06 AM
vtec95sol
45
Sep 2, 2004 06:32 PM
wm5holla
May 6, 2003 09:27 AM
b18b-HB
Sep 2, 2002 06:08 PM
