boosting issue
Old Dec 1, 2005 | 10:35 AM
typeRobtypeS's Avatar
Default boosting issue
i ran into a problem yesterday.
alright heres the application: stock gsr turbo on 10psi
and heres the problem: yesterday i was driving and i hit full boost goin around 100mph. as soon as i got up to around 7k rpm in third gear i think it was, my check engine light came on. i came to a stop and in neutral and my idle was terrible. the engine was making a loud noise and my throttle response was very poor. i shut the car off and waited a few minutes and then restarted it and it was back to normal with no CEL. since then everything seems to be fine but im jut wondering what exactly happened? my only guess would be that it sensed boost. also, it probabily doesnt matter but i just routed my dump tube to my downpipe earlier yesterday before that happened. anyone have any ideas on whats going on? thanks
Rob
Old Dec 1, 2005 | 11:07 AM
mike1114's Avatar
Default Re: boosting issue (typeRobtypeS)
small boost spike caused you to pass the voltage limitations on the MAP sensor and sent the ECU into limpmode, engine drives shitty afterwards cause its rich as hell......
Old Dec 1, 2005 | 11:13 AM
.RTErnie's Avatar
Default Re: boosting issue (mike1114)
before we can know about that... what kind of MAP sensor situation do you have? what ems? Hondata? map clamp? missing link?
boosting in high gear will cause all kinds of loading issues you wont experience in 3rd gear. 4th gear should be fine still, but 5th was not meant to be an acceleration gear. Loads the turbo significantly and causes boost issues (spiking included)
because you shut your car off and then it went back to normal we know it was not a mechanical issue...it was definitely electronic.
And since this electronic issue made your car run like ****, it was most likely your map sensors input.
btw what was the CEL?
Old Dec 1, 2005 | 12:11 PM
mike1114's Avatar
Default Re: boosting issue (RTErnie)
RTErnie.....good job on turning my two sentances into 3 paragraphs and not saying anthing new.
sorry, just giving ya a hard time.
Old Dec 1, 2005 | 12:16 PM
.RTErnie's Avatar
sometimes you have to break it down for people because they arent "experienced" enough to understand how you came to your conclusion. Just running them through the logical steps they need to use to deduct what in fact is the problem when they are troubleshooting. but yeah I said the same **** you said. lol
Old Dec 1, 2005 | 12:32 PM
LoseRPunKx182's Avatar
hmm..interesting..not to threadjack but i'm about to turbo my gsr too and going to bypass the map with a chip...what would be a solution to his problem?
Old Dec 1, 2005 | 12:34 PM
.RTErnie's Avatar
Default Re: boosting issue (LoseRPunKx182)
a chip? I would get a hondata...chrome..neptune...uberdate etc. No reason why you should risk your engine with a bandaid MAP fix. my personal opinion.
Old Dec 1, 2005 | 12:50 PM
missing link. i didnt get to check which CEL it was because it was gone as soon as i shut it off.
Old Dec 1, 2005 | 12:51 PM
.RTErnie's Avatar
if missing link then yeah...your map sensor saw boost.
Old Dec 1, 2005 | 12:57 PM
so do u think it will happen again? i plan on tuning with crome or uberdata eventually though.
Old Dec 1, 2005 | 01:02 PM
.RTErnie's Avatar
if it happened this time then yeah...it will prolly happen again. Just resist doing 5th gear pulls until you get a hondata, chrome,neptune or such.
Old Dec 1, 2005 | 01:09 PM
alright, thanks for the info
Old Dec 1, 2005 | 02:35 PM
nonvtecD's Avatar
He said he was doing a third gear pull... not fifth gear. Honestly, I wouldn't be doing any types of "pulls" with a missing link.
Old Dec 1, 2005 | 03:42 PM
Acrappyhatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTErnie &raquo;</TD></TR><TR><TD CLASS="quote">a chip? I would get a hondata...chrome..neptune...uberdate etc. No reason why you should risk your engine with a bandaid MAP fix. my personal opinion.</TD></TR></TABLE>
streethondar
Mar 3, 2011 12:03 PM
PNK SLP
Feb 21, 2011 09:56 PM
blackcrx16
25
Apr 14, 2006 06:35 AM
VTgringo
Aug 18, 2003 02:11 PM
wrXtian
Sep 12, 2002 07:26 PM
