Stock Sleeves or Darton Sleeves GE Aebs ???
What are the Pros and Cons (on any Aftermarket Sleeves other than stock)?
I know stock sleeves are limited if you do alot of Long gear pulls......
Especially on High Boost 20lb-26lbs..B18C Stock Sleeves!!
Based on a full/safe Tune how long will stock sleeves hold and last w/High Boost?
Inputs Needed?
Inputs Needed?
Who is Mr Robot?
Re: Stock Sleeves or Darton Sleeves GE Aebs ??? (spoonhatchblack)
get it sleeved, better safe than sorry, plus you can run a larger bore on sleeves
Re: (wantboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost »</TD></TR><TR><TD CLASS="quote">lets see.... 1000 for slevees vs 2500 for a block </TD></TR></TABLE>
Re: (wantboost)
hey man you better sleeve the block if you are going to make any power.Not saying you cant make power with stock but one miss read of the boost and you will be like me (busted sleeve and rod trought block) better safe that sorry
costly misstake ha ha
Re: (SSBPGSR)
wow.
looking at running stock sleeves since all the work in on stock sleeves.
cp 9:1
eagle H-Beams
stock sleeves??
Too much work & $$ if I was to re-do everything over.
But considering it a little.
cp 9:1
eagle H-Beams
stock sleeves??
Re: (SPOOLINmatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPOOLINmatt »</TD></TR><TR><TD CLASS="quote">515whp on stock sleeves here. I only do it on race gas though. i do 440 daily pump gas. </TD></TR></TABLE>
Sick # on Stockers.
Might as well chance it.
Thanks Guys.
Sick # on Stockers.
Thanks Guys.
spoon23_JDizM AkA SpOoN20
12-07-2004 03:43 AM
lemongreenhatch
103
11-16-2004 05:37 PM
