LS/Vtec Oil pressure??
Old Dec 4, 2005 | 01:00 PM
integranator's Avatar
Default LS/Vtec Oil pressure??
Hey guys, i've been hearing recent stories that the oil pressure in ls/vtec setups is too high for a reliable engine. I tried searching for anyone having problems with it, and couldn't find anything on it. Let me know what you've heard, experienced and what not so I can see if this is myth, or fact.
Old Dec 4, 2005 | 05:29 PM
Default Re: LS/Vtec Oil pressure?? (integranator)
no one?
Old Dec 4, 2005 | 06:39 PM
JDM_EH2's Avatar
TTT for answers! I'm building an LS/VTEC and would like to know also
Old Dec 4, 2005 | 06:57 PM
HondaCivicSiR1's Avatar
Default Re: LS/Vtec Oil pressure?? (JDM_EH2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_EH2 &raquo;</TD></TR><TR><TD CLASS="quote">TTT for answers! I'm building an LS/VTEC and would like to know also </TD></TR></TABLE>yea same here
Old Dec 4, 2005 | 06:58 PM
SilCiv2K's Avatar
never had a problem with mine (greddy oil press guage) or heard of anyone else with high press problems.
Old Dec 4, 2005 | 07:04 PM
JDM_EH2's Avatar
Default Re: LS/Vtec Oil pressure?? (SilCiv2K)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SilCiv2K &raquo;</TD></TR><TR><TD CLASS="quote">never had a problem with mine (greddy oil press guage) or heard of anyone else with high press problems.</TD></TR></TABLE>
I've never heard of anyone having problems either, but this thread got me thinkin
Old Dec 4, 2005 | 07:05 PM
JDM00SI's Avatar
me too
Old Dec 4, 2005 | 07:06 PM
JDM00SI's Avatar
never heard about it.....
i heard if its tuned right its reliable.
Old Dec 4, 2005 | 10:25 PM
drift2004's Avatar
Default Re: (JDM00SI)
they say ls/vtec arent reliable because of the stroke meaning the pistons are being pushed to the cylinder walls , unlike the gsr or b16 the pistons does not push that much to the cylinder walll, thats my example. and then people rev them out to 8k when ls are meant to rev to 7k get some better rod bolts or yet rods my 2 cents
Old Dec 4, 2005 | 10:44 PM
Dunc's Avatar
BCICAN
Default Re: (drift2004)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drift2004 &raquo;</TD></TR><TR><TD CLASS="quote">they say ls/vtec arent reliable because of the stroke meaning the pistons are being pushed to the cylinder walls , unlike the gsr or b16 the pistons does not push that much to the cylinder walll, thats my example. and then people rev them out to 8k when ls are meant to rev to 7k get some better rod bolts or yet rods my 2 cents</TD></TR></TABLE>
I'd basically agree with this in the sense that people just bitch and moan about the R/S being "crappy". It's really not bad, and an ls/vtec can be just as "reliable" as any other turboed honda....period.
As for the stock oil pump, yes I have heard several engine builders/shops say that the LS just isn't up for the task. If you can, replace it out with at least a stock GSR or something. I've had have no such oil problems, but then again I only use a stock LS pump for a few months at 375whp@14.5psi. Now I have an Endyn oil pump (basically a GSR that's been reworked for flow), and I idle around 15psi, and WOT is somewhere around 60-70psi.....I feel completely confident that this one will hold up just fine.
If it matters: I also have two oil sandwich plates. One for the ls/vtec and an one for the oil cooler. I have a -8an line going to the head, a -3an line going to the turbo, -10 lines going to the oil cooler and back, and a -3an line to the pressure gauge.
Modified by Dunc at 3:00 AM 12/5/2005
Old Dec 6, 2005 | 02:11 PM
Default Re: (Dunc)
thanks for the info-- anyone else?
Old Dec 6, 2005 | 03:41 PM
m R g S r's Avatar
only reason oil pressure may be higher (which it is...i noticed a *slight* increase over my b16a setup) is because of the lack of oil squirters. but no worries....it should be fine as long as your oil restrictor in the turbo line is the correct size.
Old Dec 6, 2005 | 05:49 PM
boost fed ls's Avatar
Default Re: LS/Vtec Oil pressure?? (m R g S r)
No problems here, I did replace the oil pump with a oem gsr one.
Old Dec 6, 2005 | 06:48 PM
boosted k20's Avatar
Default Re: LS/Vtec Oil pressure?? (boost fed ls)
using a LS pump in my LS/VTEC. idle im at 20psi and WOT im at 80-85 psi. OBD2 LS oil pump = GSR, ITR oil pump
Old Dec 7, 2005 | 05:50 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r &raquo;</TD></TR><TR><TD CLASS="quote">only reason oil pressure may be higher (which it is...i noticed a *slight* increase over my b16a setup) is because of the lack of oil squirters. but no worries....it should be fine as long as your oil restrictor in the turbo line is the correct size. </TD></TR></TABLE>
Will the garrett bb restrictor do
eg customs
Dec 11, 2008 05:59 AM
Ek9Max
Jun 29, 2005 08:28 AM
egtype-r
Feb 2, 2004 09:07 PM
sk!tz0
10
Jul 13, 2003 09:55 AM
skribblah
10
Jun 20, 2003 09:37 PM
