Will this sandwitch adapter work with a oil cooler?
Re: Will this sandwitch adapter work with a oil cooler? (Jordo@KAP)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jordo@KAP »</TD></TR><TR><TD CLASS="quote"> Will this adpater work with a oil cooler? In and Out. </TD></TR></TABLE>
No, it will not. The purpose of our sandwich plate is to feed ONLY. It was primarily designed to feed clean filtered oil to the vtec portion of a head on an LS/VTEC conversion. It also can do turbo oil feed or pressure sending unit, but it does not have a provision for oil return from any type of oil cooler.
Re: Will this sandwitch adapter work with a oil cooler? (GoldenEagleMfg.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GoldenEagleMfg.com »</TD></TR><TR><TD CLASS="quote">No, it will not. The purpose of our sandwich plate is to feed ONLY. It was primarily designed to feed clean filtered oil to the vtec portion of a head on an LS/VTEC conversion. It also can do turbo oil feed or pressure sending unit, but it does not have a provision for oil return from any type of oil cooler.</TD></TR></TABLE>
Could i use this to "feed the turbo and the oil cooler" then route the oil cooler back into the block where my current oil feed is now?
edit: that wouldnt work either, itd be pluged into another feed (in)
Modified by Jordo@KAP at 1:43 PM 12/2/2005
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jordo@KAP »</TD></TR><TR><TD CLASS="quote">Could i use this to "feed the turbo and the oil cooler" then route the oil cooler back into the block where my current oil feed is now?</TD></TR></TABLE>
Probably not because I'd imagine there would be a drop in pressure.
I'd get one and use one port for your turbo and one port for your oil cooler. Just run a return line to your oil pan just like the one for your turbo return.
Re: Will this sandwitch adapter work with a oil cooler? (Everyones Hero)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Everyones Hero »</TD></TR><TR><TD CLASS="quote">Probably not because I'd imagine there would be a drop in pressure.
I'd get one and use one port for your turbo and one port for your oil cooler. Just run a return line to your oil pan just like the one for your turbo return.</TD></TR></TABLE>
that is how it is now, but it doesnt even cool the engine oil. only the turbo gets the cooler oil..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jordo@KAP »</TD></TR><TR><TD CLASS="quote">that is how it is now, but it doesnt even cool the engine oil. only the turbo gets the cooler oil..</TD></TR></TABLE>
So you have two pressurized ports, one feeding the turbo and one feeding an oil cooler?
