glowshift gauges
Old Dec 5, 2005 | 01:26 PM
PearlWhiteAccord's Avatar
Default glowshift gauges
does anyone have them?? are they reliable and accurate?? or does someone know any other company that isnt that expensive?? Please let me know, thanks..
also, i am running an apexi turbo kit on a 95 sol si (d16z6 sohc vtec) and would like to know what injectors i need to run?? specs? plug & play?
noob at this, tia!!!
Old Dec 5, 2005 | 01:38 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: glowshift gauges (PearlWhiteAccord)
do not leave your monitoring up to "cheap inexpensive" gauges. no you dont need to run defi gauges, but atleast go with some sport or pro comp gauges.
as far as the injectors you will need, they are up to your power goal.
go to http://www.rceng.com/technical.htm#WORKSHEET
and get the size that you need. as for p+p most likele you will either need to dremel your connectors, or go to obd0 clips.
Old Dec 5, 2005 | 01:40 PM
Default Re: glowshift gauges (boostedcivicsir)
so i should get the autometer ones...any difference in mechanical and elect???
all i need is oil press and boost rite??
i will be only pushing 6-8psi max
Old Dec 5, 2005 | 01:42 PM
just went to site, how do i know the duty cycle and fuel pressure?? sorry, i am noobie at turbo
Old Dec 5, 2005 | 01:58 PM
Soccerking3000's Avatar
i have glow shift guages, the boost guage is spot on with crome when i datalog, i would hope the same for the oil pressure sender. I dont have any complaints
Old Dec 5, 2005 | 04:42 PM
so simple's Avatar
i have the boost and oil press. gauges. car isnt tuned yet so no boosting, so the boost gauge reads vacuum all the way(is that right?) so the boost gauge seems to be working. the oil pressure gauge however stays at 0. pretty sure i hooked it up right so it may be a crap gauge there.
Old Dec 5, 2005 | 06:39 PM
Default Re: (so simple)
if i am running on basemap, wouldnt i hit boost ??? shouldnt the gauge register??
Old Dec 5, 2005 | 07:07 PM
so simple's Avatar
i was saying that i personally have not hit boost yet because i havent tuned my car. was saying that the gauge reads vacuum so it seems to be working and should read boost when i finally boost it
CMTurbo99
Aug 28, 2010 02:49 PM
thumper64
Mar 10, 2010 09:35 AM
Mario.
Jul 1, 2004 05:05 PM
TurbothisLS
Aug 25, 2002 05:42 PM
Snafu-Si
May 3, 2002 09:27 AM
