boost/vac gauge questions
Old Dec 4, 2005 | 04:17 PM
soontobeboost's Avatar
Default boost/vac gauge questions
i installed a auto meter boost/vac gauge on my integra the other day and heres the thing.
- vac reads at 22
- when i step on the gas pedel the vac needle does not go towards 0
- when i full throttle it in 1st gear it takes about 2 sec for the neddle to jump to 0 (its stays at 22 then just jumps up to 0 rite away after 2 sec)
- full throttle in any other gear vac does not go towards 0
so what should i check for? or is the gauge broken? i bought it brands spankin new so ya
Old Dec 4, 2005 | 04:28 PM
platinum00's Avatar
Default Re: boost/vac gauge questions (soontobeboost)
22 is about normal.
about it not moving correctly. are you sure a line is not pinched somewhere.
check near the firewall
platinum
Old Dec 4, 2005 | 04:31 PM
bubs's Avatar
Where are you getting your vac. source from?
If I had to guess, I'd say you installed it on the brake booster line AFTER the inline check valve and the check valve is keeping any vacuum from escaping.
Old Dec 4, 2005 | 04:49 PM
Default Re: boost/vac gauge questions (platinum00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by platinum00 &raquo;</TD></TR><TR><TD CLASS="quote">22 is about normal.
platinum</TD></TR></TABLE>
line is not pincehd... checked it today and line was ok
Old Dec 4, 2005 | 04:52 PM
Default Re: (bubs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bubs &raquo;</TD></TR><TR><TD CLASS="quote">Where are you getting your vac. source from?
If I had to guess, I'd say you installed it on the brake booster line AFTER the inline check valve and the check valve is keeping any vacuum from escaping.</TD></TR></TABLE>
not to sure what its called...ummm i think its the line where it connects to the butterfly vavle...
Old Dec 5, 2005 | 10:00 AM
Default Re: (soontobeboost)
got it to work. i noticed that only when i hit around 6k rpm that it will jump to zero... so then i realized that i t'ed off where the butterfly valve is at. so then i un t'ed that and t'ed it to antother vacume line and all works fine now.
R6E6I6D
Nov 21, 2005 06:47 PM
DeDonDeRosa
Sep 19, 2005 04:05 PM
97dc2
Jul 21, 2005 10:47 AM
91civtegra
Feb 25, 2005 08:37 PM
92JDMSiR
Aug 1, 2002 09:18 PM
