fuel management
Old Dec 5, 2005 | 02:13 PM
Turbo_y8's Avatar
Default fuel management
alright im gunna be runnign about 6-8psi through my d16y8, i really want to keep obdII due to emissions and such, i know hondata has to be obdI, which is kinda what i wanted, btu some other suggest vafc and get it properly tuned, would that cut it, btw fuel systme consists of 255 walbro and 310cc injectors, do i need a fule press. reg. or not. thank you
Old Dec 5, 2005 | 02:57 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: fuel management (tuck'd98)
you need fuel/ignition management. a vafc will not cut it... you can drive around obd1 until its time for inspection, then just put the stock ecu and injectors back in an wire your wg open
Old Dec 5, 2005 | 02:59 PM
SOHC_MShue's Avatar
Default Re: fuel management (wantboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">you need fuel/ignition management. a vafc will not cut it... you can drive around obd1 until its time for inspection, then just put the stock ecu and injectors back in an wire your wg open</TD></TR></TABLE>
I agree. Screw using an afc. They are junk.
Old Dec 5, 2005 | 03:06 PM
Turbo_y8's Avatar
thats a good idea, thanx guys, they only way i would get a vafc was just to meter the a/f and vtec engagment, and what note, but im sure an a/f gauge will cut it and ill get a sweet light show
redmethods
Jun 21, 2005 07:36 PM
Aracheon
Apr 23, 2005 05:56 AM
WONG FRIED RICE
Jul 15, 2003 10:52 AM
comptechgsr
Mar 19, 2002 10:53 AM
Turbohatch
Jul 31, 2001 11:25 AM
