adjusting actuator
Old Dec 2, 2005 | 04:50 PM
EH-3's Avatar
Default adjusting actuator
can u adjust the actuator arm to increse boost? if so, how?
Old Dec 2, 2005 | 05:09 PM
EH-3's Avatar
Default Re: adjusting actuator (EH-3)
ne one?
Old Dec 2, 2005 | 09:12 PM
eastbay92cx's Avatar
I suppose you could by shortening the actuator arm, cut a section of the rod out and thread it and use a threaded sleeve. If you shorten the arm, it should open the actuator somewhat while keeping the wastegate closed, and hopefully it will take a stronger signal (more boost) to open the wastegate. I've never tried it. Good luck.
btw you can also make a mbc from some home depot pieces. seach google.
Old Dec 2, 2005 | 09:30 PM
SWC's Avatar
SWC
Default Re: adjusting actuator (eastbay92cx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eastbay92cx &raquo;</TD></TR><TR><TD CLASS="quote">I suppose you could by shortening the actuator arm, cut a section of the rod out and thread it and use a threaded sleeve. If you shorten the arm, it should open the actuator somewhat while keeping the wastegate closed, and hopefully it will take a stronger signal (more boost) to open the wastegate. I've never tried it. Good luck.
btw you can also make a mbc from some home depot pieces. seach google.</TD></TR></TABLE>
What he said. By shortening the arm would make the wastegate spring stiffer meaning hold higher boost. If your arm is 2 pieces connected together by thread, you can adjust it.
Good luck!
Old Dec 3, 2005 | 10:46 AM
EH-3's Avatar
Default Re: adjusting actuator (SWC)
ne one else? if i helps any. im running a little tdo4-h and the actuator arm has a nut and threaded sleeve on it. so does that mean its adjstable?
Old Dec 3, 2005 | 10:19 PM
SWC's Avatar
SWC
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EH-3 &raquo;</TD></TR><TR><TD CLASS="quote">ne one else? if i helps any. im running a little tdo4-h and the actuator arm has a nut and threaded sleeve on it. so does that mean its adjstable?</TD></TR></TABLE>
Yes. Just loosen a lock nut and remove tiny C-clamp or pin which secures the actuator arm. Then take the arm off from the wastegate lever and turn it for adjusting. You need to make it shorter for higher boost or vice versa.
Old Dec 3, 2005 | 10:22 PM
.RTErnie's Avatar
yay more boost.
Old Dec 4, 2005 | 01:45 AM
EH-3's Avatar
Default Re: adjusting actuator (RTErnie)
N20civicB18
Dec 27, 2006 09:22 AM
Mag00n
Jun 26, 2006 09:36 PM
moesrex
May 15, 2006 08:34 AM
MayhemSi
Sep 6, 2003 11:47 AM
BoostedsiR
May 15, 2003 06:59 PM
