spooling a t3 60-1
Old Dec 4, 2005 | 01:56 AM
rudebwoy's Avatar
Default spooling a t3 60-1
any experience with the 60-1 turbo on a b16? what is the spool time?
Old Dec 4, 2005 | 03:30 AM
crucian's Avatar
Default Re: spooling a t3 60-1 (rudebwoy)
Basically what he would like to know is if anyone had any experience with both a 60-1 and SC61. Which one will have a better response time if both were using a .63 turbine housing? Thanks for any help!
Old Dec 4, 2005 | 03:41 AM
BlueShadow's Avatar
Default Re: spooling a t3 60-1 (crucian)
I was having a hard time deciding between a T3/60-1, T3/T61 and an SC6152S. I ended up forking over the extra money and went with the SC6152S.
https://honda-tech.com/zerothread?id=1358621
Old Dec 4, 2005 | 10:30 AM
rudebwoy's Avatar
anyone
Old Dec 4, 2005 | 10:54 AM
JDM_EH2's Avatar
Both are gonna spool really late on a B16. Here are some examples:
T3/60-1
http://forums.evans-tuning.com...=2338
SC61
http://forums.evans-tuning.com...=2475
It's not really a fair comparison IMO due to the differences in PSI, but you can get a general idea. If choosing between those 2 turbos I'd go with the SC61. They spool about the same but the SC61 is capable of a bit more power. How much power are you looking to make anyway? Both of these turbo's could be overkill...
Old Dec 4, 2005 | 11:11 AM
used2baracer's Avatar
Default Re: spooling a t3 60-1 (JDM_EH2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_EH2 &raquo;</TD></TR><TR><TD CLASS="quote">How much power are you looking to make anyway? Both of these turbo's could be overkill...</TD></TR></TABLE>
This is my experience with customers 95% of the time. If you're looking for MORE Than 500hp, use those turbos. However a 60 Trim T3/T04e may get you the same numbers with quicker spool time and a little more boost, but a much better (useable) power band.
Old Dec 4, 2005 | 11:49 AM
rudebwoy's Avatar
I currently have a 60 trim t3/t4 at 20 psi and I am not satistfied, I want to make atleast 500 whp. I am having a hard time chosing a upgrade right now, so any help will be good
Old Dec 4, 2005 | 02:24 PM
JDM_EH2's Avatar
Default Re: (rudebwoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rudebwoy &raquo;</TD></TR><TR><TD CLASS="quote">I currently have a 60 trim t3/t4 at 20 psi and I am not satistfied, I want to make atleast 500 whp. I am having a hard time chosing a upgrade right now, so any help will be good</TD></TR></TABLE>
OK. In that case I would go with the SC61, if you're limited to those 2 turbos. Otherwise there are other options out there that may be better suited to you're needs, both in spool time and power. Contact Mac, the shodan, on here. He'll set you up with something nice Good luck with your set-up man!
Old Dec 10, 2005 | 06:44 PM
rudebwoy's Avatar
I ordered the sc61 today, no turning back now. I think it will suite my application, my boy running the same one, and he still spanked my *** on both take off and top speed, same motor, plus I have a little bigger bore block, so that may help a little
Old Dec 10, 2005 | 08:53 PM
BoostR41's Avatar
should have ordered a T3/60-1 with BB center section....
Old Dec 10, 2005 | 10:45 PM
SSBPGSR's Avatar
Default Re: (BoostR41)
i think you made a mistake by going with the sc61. back when it was the bandwagon i went ahead and got a 60-1 and i havent had any regrets, i make full 22psi at 5200RPM and i made 472whp on a dynapack. NOT a dynojet. it spooled faster than a friends sc61 and made just about the same power. if its not to late i would cancel the order and re-concider. just my opinion.
Old Dec 12, 2005 | 12:09 PM
rudebwoy's Avatar
the 60-1 is too f@#%king huge for something that put out less power that the sc61, believe me everyday I go to the pheonixturbo site staring at the 60-1 with phone and debit card in my hand, just couldn't make up my mind. then My boy got the sc61 and I got the t3/t4 60 trim with 48ar, and I only made 239whp at 14psi and I was unhappy with that, he used the sc61 at 10psi, and he was tearing me apart, he is undefeated, against all, me, I beat on most. but still I cannot beat him off the line or on a roll. he convinced me that the sc61 was a good choice, plus if I get the 60-1, I would have to change all my turbo side piping, because the piping on that side is 2.25,and I would not be able to use a filter on the 4 inch inlet on the 60-1. but the sc61 is a direct swap. so those are the things that helped me to chose the sc61
Modified by rudebwoy at 7:47 PM 2/26/2006
Old Dec 12, 2005 | 12:39 PM
SSBPGSR's Avatar
either way, you got a sick turbo congratulations and enjoy
littletriad
Aug 10, 2006 02:41 PM
model x
Jun 4, 2004 02:32 PM
Ri5e
Aug 24, 2001 07:59 AM
