What do you think happend to this Piston? PICS
UPDATE ON PG 3
After a good 6 months of a strong running car with no issues it was time for something to happen, just didnt want it to be this bad. Oh well i will come back bigger and better!
Now for the question, what do you think happend? Injector failure? The car was running fine without any issues before this happend. I pulled out the 880 injectors the day before to go with 1000's but one was bad so i put my orginal injectors back in which i had run for 6 months. Then on Race Day in qualifying the car went 10.43@ 141.84 and laid over right as i went through the traps.
Heres a vid of the run. Sorry for the end its short, the car let a small puff of white smoke out through the traps.
http://www.one-fab.com/Persona...1.wmv
I am 100% sure it wasnt the Tune so thats out of the Question.
Heres a link to when it was tuned.
https://honda-tech.com/zerothread?id=1302002
Modified by alopez84 at 3:47 AM 1/5/2006
Modified by alopez84 at 12:09 PM 1/5/2006
Modified by alopez84 at 12:10 PM 1/5/2006
burned it. too lean/lack of fuel for whatever reason. you said you just reinstalled the injectors... any chance the clip wasn't getting a good connection? you said one of the 1000s was bad... maybe it wasn't, but your injector driver or injector wiring was actually the culprit.
yeah man sorry to say there was quite a bit of etonation goin on in there because you can see the pitting marks from heat on the outer ring of the plug and along the cylinder wall there was some heat building up inside... also i think i see some out of roundness on the edges of the piston like it was rounding off or meltitng away... hmmm
Re: (RacerXI)
The only thing I can tell is that their appears to have been excessive heat in that cylinder. Hard to get any info off of the plug because it's oil soaked and I see some hairline cracks on the piston that may have been caused by detonation. I would suspect injector failure at this point because all the other cylinders look fine. Send them to be flow checked and mark the injector that was removed from that cylinder. Were you under load when this happened or was it right when you let out of the throttle? The plugs look a lil' lean to me.
Phil
Phil
Re: (wantboost)
We understand what caused the damage. We are trying to figure out what cause the detonation and heat in that particular cylinder. The AFRs were 11.3-11.5:1 AFRs on C16 only.
Re: (adSPEED)
Interesting that it failed on the exhaust side of the chamber. Usually seems to happen on the intake side.
Atleast the head appears to be ok in the pics; coulda' been worse $$$
Re: (Jared)
Not yet we are still trying to figure it out. I am going to get the injectors flow tested to see if that was the problem. Just tyring to get more opinions on what happen because i have never seen anything like this before.
Thanks Aaron
Thanks Aaron
Guest
Posts: n/a
Re: (B18 CYA)
I'm guessing you only have one wide band probe like 99% of us right? that probe is measuring all 4 cylinders at the same time so maybe if one leaned out it wouldn't show up. Maybe the injector wasn't firing for whatever reason in that cyl?
it Detonated period
and it was a nice strong one
remember it only takes 1-2 good strong BAD detonations to blow an engine.... doesnt really need to detonate for a while
Re: (USDM 4G VTEC)
I would pull the piston and check to see if the 1st or 2nd ring is pinched.
If this happens it will start a change reaction of bad events.
But the question is... why. The injectors should be flowed to see if thats the culprit.
Re: What do you think happend to this Piston? PICS (alopez84)
I had some c16 go bad once and it immediately turned a good motor into one that looks like yours.
If that is not your problem, obviously excessive heat caused this damage and #3 cylinder runs the hottest. Usually this kind of damage is caused from excessive timing in that cylinder or too much timing overall and that takes out the hottest cylinder first.
If an injector is not firing at all, that cylinder will not make any heat at all as that takes fuel to accomplish.
One thing to note is that you said the motor laid over in high gear. That is when the motor is loaded the heaviest (working the hardest) and thus generating the most heat.
Re: What do you think happend to this Piston? PICS (earl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl »</TD></TR><TR><TD CLASS="quote">I had some c16 go bad once and it immediately turned a good motor into one that looks like yours.
One thing to note is that you said the motor laid over in high gear. That is when the motor is loaded the heaviest (working the hardest) and thus generating the most heat.</TD></TR></TABLE>
Hmm... That makes me think. I did put about 2.5 gallons of C-16 into my tank the day before, but i always keep it above 1/2 tank so that means it would have about 6 gallons to mix with in there when i made this run. What makes C-16 go bad i only had it about a week and ran with the other 2.5 gallons the week before.
As for the timing issue why would it take 6 month and over 60+ passes for this to happen.
Aaron
Aaron
