Sorry another clutch question
Old Dec 2, 2005 | 10:01 PM
carblegal's Avatar
Default Sorry another clutch question
Which clutch can hold the power and still last as long as a stock clutch (normal driving)?
I have about 230hp and 170tq and been having problems with the clutch holding my power (spring popping out of the clutch disk), I was thinking about the titlon single metal clutch but they told me their clutch disks need to be replaced before 15000 miles of normal driving.(more if I really abuse it, ie drag or road race)
Which clutch do you all run? I am looking for one that can take the abuse (not slip/break) of 8000rpm launches without popping springs out and have decent clutch life when driven on the street.
Old Dec 2, 2005 | 10:36 PM
onemanlan's Avatar
Why do you need to do 8k clutch drops?
That's a lot of uneeded abuse to the clutch.
LSDmotorsports.com carries nice clutches that have had little to no problems. Not to mention their prices are very reasonable.
Old Dec 2, 2005 | 10:38 PM
pgmatt's Avatar
Default Re: (onemanlan)
LSD Motorsports is def the way to go.Just tell him your application and he will take care of you.
Old Dec 3, 2005 | 06:19 PM
carblegal's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onemanlan &raquo;</TD></TR><TR><TD CLASS="quote">Why do you need to do 8k clutch drops?
.</TD></TR></TABLE>
Cause I bog on slicks if I launch any lower.
Old Dec 3, 2005 | 07:04 PM
Importordomestic's Avatar
Default Re: (carblegal)
your running slicks on 230hp? and 176wt? JESUS! what do those slickes take off your et? .00001 of a second? oh my bad i forgot that you break the clutch when you do that. just run street tires and drop the revs... you will then stop breaking clutches and get better et's.
With all that aside
well if you get a higher stage clutch and you do a 8k clutch kick on drag slicks your going to break something expensive. like Axles. transmission housings - differentials.
Old Dec 3, 2005 | 10:18 PM
carblegal's Avatar
Default Re: (Importordomestic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Importordomestic &raquo;</TD></TR><TR><TD CLASS="quote">your running slicks on 230hp? and 176wt? JESUS! what do those slickes take off your et? .00001 of a second? oh my bad i forgot that you break the clutch when you do that. just run street tires and drop the revs... you will then stop breaking clutches and get better et's.
If I run street tires either I spin the crap out of them during launch OR after the weak launch without spinning the tires--&gt;VTEC switch over and the street tires spin till redline
Slicks take off almost a second and half for me because Im not spinning the tires.
well if you get a higher stage clutch and you do a 8k clutch kick on drag slicks your going to break something expensive. like Axles. transmission housings - differentials. </TD></TR></TABLE>
Thank you, your opinion has been noted.
Modified by carblegal at 11:31 PM 12/3/2005
DANgerous
Apr 4, 2004 01:37 PM
Kellindal
Feb 28, 2002 11:17 AM
SilverS
Feb 26, 2002 02:21 PM
ALF
Nov 30, 2001 09:58 PM
