S300 with JDM P30
Old Dec 2, 2005 | 10:40 PM
SpiderSol's Avatar
Default S300 with JDM P30
is it possible to use S300 with JDM P30
Old Dec 2, 2005 | 10:53 PM
Stylinhonda's Avatar
Default Re: S300 with JDM P30 (SpiderSol)
Im wondering the same question? What do you JDM P30 ECU guys use for managment
Old Dec 2, 2005 | 11:49 PM
SpiderSol's Avatar
Default Re: S300 with JDM P30 (Stylinhonda)
i'm using a programmed chip with uberdata now and planning to go with S300 all i want is to make sure that the s300 can be installed into my ecu
Old Dec 3, 2005 | 12:05 AM
riceball777's Avatar
the s300 cant be installed in the jdm square ecu's then need to be installed in the rectangle ecu's
Old Dec 3, 2005 | 12:18 AM
SpiderSol's Avatar
Default Re: S300 with JDM P30 (riceball777)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riceball777 &raquo;</TD></TR><TR><TD CLASS="quote">the s300 cant be installed in the jdm square ecu's then need to be installed in the rectangle ecu's</TD></TR></TABLE>
is it only becuase of the shape of the ecu or the board it self, i can modifie the shape of my ecu if thats the only problem.
Old Dec 3, 2005 | 12:34 AM
no clue but all hondata says is just that its not compatiable with square jdm ecu's
Old Dec 3, 2005 | 12:41 AM
SpiderSol's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riceball777 &raquo;</TD></TR><TR><TD CLASS="quote">no clue but all hondata says is just that its not compatiable with square jdm ecu's</TD></TR></TABLE>
this is what i read too but i want to know if someone tried to install it......
Old Dec 3, 2005 | 08:18 AM
So you can still use Uberdata and stuff? And it's just the shape of the JDM one that limits it?
Old Dec 3, 2005 | 03:24 PM
Manny_Fresh's Avatar
i got NEPTUNE on my JDM P30
Old Dec 3, 2005 | 10:53 PM
SpiderSol's Avatar
Default Re: S300 with JDM P30 (H2kEg6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H2kEg6 &raquo;</TD></TR><TR><TD CLASS="quote">i got NEPTUNE on my JDM P30 </TD></TR></TABLE>so can i use s300 on my ecu
Old Dec 4, 2005 | 04:50 AM
Dee's Avatar
Dee
You will need to get a USDM ECU. I am using a USDM P72 in my car instead of the JDM P72 that I used with my S200.
The internal bracing and mount for the P72 daughterboard prevents the S300 from being installed. The P30 will have similar issues.
Old Dec 4, 2005 | 08:55 AM
Default Re: S300 with JDM P30 (Dee)
That sux. Are there any problems using the free programs like chrome, uberdata and neptune with the P30? Since there are no fitment issues it should be ok right?
Old Dec 4, 2005 | 06:08 PM
Dee's Avatar
Dee
Just trade your JDM ecu for a USDM ecu.
I CRX I
Apr 19, 2008 08:07 AM
pinoyboy204
Jul 5, 2006 10:28 PM
DasaEJ1
Aug 10, 2005 06:42 PM
shift6th
Honda S2000
Apr 4, 2004 07:32 PM
DB8ITR
Dec 6, 2003 12:34 AM
