Rich or lean 42 psi
Old Dec 4, 2005 | 12:08 PM
nfinitecc's Avatar
Default Rich or lean 42 psi
i have a B&M command Flo FPR and a walbro 255 intank and Type r 310 injectors W/ a vortec FMU, im reading 42 PSI at IDLE. I heard prior to install that with the FPR and Walbro i wouldnt be able to get the pressure back down, my question is is 42 to high at idle? i have the FPR all the way down. It runs GOOD witht his setup but my A/F gauge does no good cause it bounces around like crazy all the time anyway. Does this setup sound like it would run lean on 5 pounds? its a D16Y7 BTW Thanks
Old Dec 4, 2005 | 12:09 PM
93turbo16's Avatar
get a wideband and find out for sure.
Also do you have anything controlling the 310s? Any other sort of management.. if not it will run rich,
Old Dec 4, 2005 | 01:13 PM
nfinitecc's Avatar
Default Re: (93turbo16)
im not running any managment just intank, FPR, FMU, Bigger injectors,missing link. I have RC 550's i just had to get the FPR and pimp in to save money on tuning and all that Neptune on 10 PSI
Old Dec 4, 2005 | 02:45 PM
.2000psi.
Guest
Posts: n/a
Default Re: (nfinitecc)
dunno bout the first question but you can drill that B&M with a larger return hole to be able to lower the pressure. endyn has a writeup on it.
bluesi00
Jun 7, 2004 09:04 PM
Ryan C
May 26, 2003 08:36 PM
ZEXGS-R
May 19, 2003 10:13 PM
J.R.
Apr 4, 2003 07:36 AM
integraracer94
May 19, 2002 09:12 PM
