Where do you source your WGA's vacuum line from?
most of us run EBC's or MBC's...or have them controlled by the ems through an actuator valve. My question is where do you guys source your vacuum signal for your lower wastegate port?
i run mine straight from the intake manifold...and im wondering what kind of benefits/changes will be made if i were to tap my compressor housing? Let me know what you're running and why you chose to do it that way(theory? or just because it was convenient)
Re: Where do you source your WGA's vacuum line from? (RTErnie)
I <3 the utah option. hahahha. intake manifold for my AVCR, as it comes from my vacuum manifold. lower wastegate line comes from turbo housing via SS line.
Re: Where do you source your WGA's vacuum line from? (boostedcivicsir)
take it from the compressor housing and use brainded line with an fittings. This will prevent any problems with a leak or line failure which in turn will save your motor from overboost.
