need help choosing between options for my setup
Old Dec 4, 2005 | 09:04 PM
b16spaz's Avatar
Default need help choosing between options for my setup
first off heres the things done to the car 00si
-weisco flat top pistons
-eagle H-beams
-CTR cams
-skunk2 Pro IM
-N1 apexi & hi flow cat
-greddy 18g w/ FM & tial bov & ext WG (not installed yet)
-650cc's
-walbro 255 pump
-CM stage4
im kinda stuck right now in dept so cant afford to get a tune for a while, and need to get the car running again and got a couple of questions. just dont want it to run like **** or damage anything w/o a tune
-if I was to put pack on my intake and header and drive it on the factory ecu with the low comp and walbro pump would it run ok for a few weeks until i could get a tune?
-or use the emanage until i can get a tune, would that be fine also? or would it not be able to calibrate the cams and low comp in its fuel management?
..open to all sugestions and comments..
Modified by b16spaz at 4:49 PM 12/5/2005
Old Dec 5, 2005 | 01:50 PM
b16spaz's Avatar
Default Re: need help choosing between options for my setup (b16spaz)
bump
1EG2NV
Oct 28, 2008 01:00 PM
93egallmotor
May 1, 2007 03:08 PM
kaptr1d
Mar 21, 2004 01:12 AM
Simple
Aug 17, 2003 10:19 AM
StinkyTofu
Dec 30, 2001 11:35 AM
