B series Fuel Rail that come's pre tapped for Bosch injectors
So I need a 14mm Fuel rail for my 1600cc Bosch injectors. Yes, you can mod the injectors I just am running out of time before my E85 tune. Mr Gasket did have some 14mm injector fuel rails back in the day but are now discontinued.Blah I have the OEM injector size MR Gasket fuel rail right now. The 14mm Drill bit is costly around $149. So if anyone can help me out I'd appreciate it. I've searched all day. Oh and I checked mcmaster for a 14mm drill bit they only have 1/2"
I called summit and its discontinued by vendor here is the site http://go.mrgasket.com/pdf/GSPORT.PDF
I just had to buck up and have my injectors modded by Five0 motorsports. They had mine done and back to me pretty fast. Might wanna look them up and check.
-Chad-
-Chad-
Re: (KaoticBrd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KaoticBrd »</TD></TR><TR><TD CLASS="quote">A 1/2(.500) inch drill bit is only 51 thousanths less than a 14mm(.551) try a 17/32 drill bit its 2/32 over 1/2</TD></TR></TABLE>
the correct bit to drill/bore the fuel rail can be found @ kinsler injection http://www.kinsler.com
Re: B series Fuel Rail that come's pre tapped for Bosch injectors (Redwidow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redwidow »</TD></TR><TR><TD CLASS="quote">So I need a 14mm Fuel rail for my 1600cc Bosch injectors. Yes, you can mod the injectors I just am running out of time before my E85 tune. Mr Gasket did have some 14mm injector fuel rails back in the day but are now discontinued.Blah I have the OEM injector size MR Gasket fuel rail right now. The 14mm Drill bit is costly around $149. So if anyone can help me out I'd appreciate it. I've searched all day. Oh and I checked mcmaster for a 14mm drill bit they only have 1/2"
I called summit and its discontinued by vendor here is the site http://go.mrgasket.com/pdf/GSPORT.PDF</TD></TR></TABLE>I got my rail from this place. i didnt see a b series listed but you might ask. http://cgi.ebay.com/ebaymotors...ZWDVW
Re: (havok hybrid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by havok hybrid »</TD></TR><TR><TD CLASS="quote">BDL makes a rail that might help you. Im gonna guess and say there is only 2 different sized bungs for injectors..
BDL.
Laskey racing can get you one. </TD></TR></TABLE>
Great!!...In stock?<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoolin hatch »</TD></TR><TR><TD CLASS="quote">I got my rail from this place. i didn't see a b series listed but you might ask. http://cgi.ebay.com/ebaymotors...ZWDVW</TD></TR></TABLE>Yeah i looked on ebay,, looks like mr gasket just discontinued the fuel rails and closing them out..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigbadboy »</TD></TR><TR><TD CLASS="quote">whats the diff between the bosch and the precision?? my precision 1600's fit my stock rail with no problems</TD></TR></TABLE>
Well my precision/Rodchestor 1000cc looked to be trimmed and modified to fit my Honda fuel rail, so maybe they are Bosch sized in the beginning
a 17/32=34/64 that would be too loose, I'd need a 33/64 bit, I'd rather just get a new fuel rail made for these injectors... bits are pretty costly anyway.. thanks!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18bturbo »</TD></TR><TR><TD CLASS="quote">holley, edelbrock make the rails you need as well
should be pn EDL4797
let me know i might have one laying out </TD></TR></TABLE>
Thanks I looked them up on summit estimated ship date 10/23/07 need one faster but if you have one hit me up I'd like a red one or plain aluminum if you got, but beggars can't be choosers lol
Thanks for all the replys~~~~~
BDL.
Re: (Redwidow)
I found a bit on Grainger 14mm yay! BDL does not make a 14mm bore for bosch talked to Mike at Laskey racing..thanks for the info Mike!
I'll be drilling my Gsport fuel rail to 14mm tomorrow..
Re: (Redwidow)
Thanks for the Help Locash, Joe helped me drill the rail today and also was able to get me the FJO injector driver i was in need of E85 in a week
